Tip's for first time Injector Swapping - Ford Powerstroke Diesel Forum
post #1 of 27 Old 10-03-2013, 04:38 PM Thread Starter
BrodieBiking's Avatar
Hey guys,
Well, my truck has 370,000km on original injectors and its time to swap em out.
I've got a new set of stock injectors for now until i get my 200/80's.
Any helpful tips for swapping them out?
Thanks in advance!
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10”s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #2 of 27 Old 10-03-2013, 06:53 PM
Eco Taxi's Avatar
7.3L Injector Swap/Glow Plug Change - Idaho Turbo Diesels
I just pulled my injectors out and put new o-rings on them, I also replaced my hpop lines ans replaced the o-rings on the fittings
Back to the injectors - make sure you purge the oil/ fuel out at the end, make sure you get new o-rings - this was my first time pulling my injectors out - after completing it - it was easier than I thought
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 27 Old 10-03-2013, 09:49 PM
Metric ratcheting flexhead wrenches are sure nice when removing the p/s valve cover.
Greenman01 is offline
post #4 of 27 Old 10-03-2013, 10:12 PM
Gaius's Avatar
Quoted: 40 Post(s)
Definitely pull the inner oil plugs that are under the valve cover, and let them drain for 10-20 minutes. Get new o-rings for them (4 of them).
Replace all of your HPOP line and outer head plug o-rings at the oil rail.
Soak or pour oil all over the new o-rings and injector before install.
After install, pull the glow plugs, put the valve covers on with a bolt or two snugged down, and crank the engine over for a bit with the starter to clear the cylinders.
To help with startup, install the rear inner oil plug, and try to fill the oil rail at the front head plug with a syringe or something. Also pull the HPOP reservior and make sure it's full too. This will make it so your batteries don;t die when you start.
You may have to crank for several minutes on restart. The oil and fuel rails will have to fill. Crank no more than 20 seconds or so at a time so you don't burn the starter up. Have a battery charger or jumper cables to charge in between just in case.
Good luck!
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #5 of 27 Old 10-04-2013, 10:03 AM
CSIPSD's Avatar
Wow... some people make injector swaps much harder then they need to be...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 27 Old 10-04-2013, 10:07 AM
Gaius's Avatar
Quoted: 40 Post(s)
What stage injectors do you recommend?
05 F350 Crewcab
Gaius is offline
post #7 of 27 Old 10-04-2013, 10:43 AM
CSIPSD's Avatar
That completely depends on your HP goal...
Regardless pulling the rail plugs is a total waste of time and effort.
Joe
CSIPSD is offline
post #8 of 27 Old 10-04-2013, 10:46 AM
Gaius's Avatar
Quoted: 40 Post(s)
It was a joke. Because you seem to helpful.
Draining the rail plugs helped me quite a bit. They'll drain anyway, better the crankcase than the cylinder IMO.
05 F350 Crewcab
Gaius is offline
post #9 of 27 Old 10-04-2013, 11:36 AM
CSIPSD's Avatar
There is no reason to drain them. It opens up another place to leak, another thing to forget and another thing to drop into the crankcase...
Remove #7 and #8 and then remove all the glow plugs. Once you have the glow plugs out then pull the remaining injectors.
Install your new injectors, set the valve covers with one bolt and bump the starter solenoid a few times.
After that then hold the starter for about 15 seconds.
Install glow plugs, finish install and start.
Cycle the key a few times so the fuel rails are full then crank. No reason to prime the hpo res, rails or otherwise mess with the hpo system...
Ever heard of K.I.S.S???
Joe
CSIPSD is offline
post #10 of 27 Old 10-04-2013, 01:04 PM
Gaius's Avatar
Quoted: 40 Post(s)
So you drain them into 7 and 8. I pull the plugs. Pretty simple to pull 4 plugs to me, but to each their own.
05 F350 Crewcab
Gaius is offline
