Leak from powersteering gear box - Ford Powerstroke Diesel Forum
post #1 of 25 Old 10-01-2013, 08:07 PM Thread Starter
usteffenhagen's Avatar
So I noticed today that I am leaking a decent amount of
PS fluid and I'm almost positive that it is from the line that goes to the top of my gear box. I haven't had time to do a detailed look and I probably won't tomorrow with the schedule I have. BUT it could also be from the seal where the pitman arm connects because that it where it drips. Not sure if it's from top or bottom. Any insight? I'm mainly asking to see if there's any common issues with either of those spots for leaks.
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 25 Old 10-01-2013, 08:51 PM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
Spray it down with break cleaner. That should allow you to see better where its coming from.
Corey@CNCFAB is offline
post #3 of 25 Old 10-01-2013, 10:13 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
atf is leaking out right. check the lines first and see if they are leaking.
cause if their is power steering fluid in there, you need to get it out.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 25 Old 10-02-2013, 02:42 AM Thread Starter
So I should have been running atf in there?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #5 of 25 Old 10-02-2013, 04:35 AM
Yes ATF not power steering fluid.
2002 F350 XLT CC SB 4x4
Riff Raff 6637
PHP TS PHX chip
SC II
Muffler delete
American outlaw wheels
Cooper Discoverer ATP tires
ELC coolant w/Dieselsite bypass filter
celltech is offline
post #6 of 25 Old 10-02-2013, 04:43 AM Thread Starter
Oops. Will it screw anything up using ps fluid?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 25 Old 10-02-2013, 04:54 AM
Quoted: 862 Post(s)
Yes. It will. Especially if you've had it in there awhile. It will tear up the seals and its not good on the pump gears. That's probably why your leaking fluid. You may only have to replace an O-ring if its the pressure line on top of the gearbox.
Do a flush ASAP. There is a very good YouTube video.
Search: 7.3 power steering flush
post #8 of 25 Old 10-02-2013, 05:48 AM Thread Starter
Wow crap ok I'm glad I posted this. The ps fluid has only been in there a few weeks maybe a month. I'll do a flush ASAP thanks for the tip
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #9 of 25 Old 10-02-2013, 12:46 PM
Quoted: 283 Post(s)
no problem
ive definitely made my share of mistakes.
post #10 of 25 Old 10-03-2013, 11:39 AM
Quickhorse's Avatar
You might end up needing a gearbox if it's already leaking. It's not easy but not that hard to change that gearbox out. Hardest part is getting the pitman arm off. Post back if you need help with that.
2008 F350 CCSB FX4 Amsoil fluids, S&B intake, 5" exhaust, Egr delete, Boss V plow, Mega Duty Title mod.
Quickhorse is offline
