I can feel some kind of rattle/noise in the front end of my 1999 F-250. I have replaced tie rods, tie rod ends, steering damper, ball joints, axle hub bearings and seals all in the last year. I did all this when one of the hub bearings locked up. I cant find anything loose or worn that I hasnt been replaced. But I can still feel something in the front end when Im driving down the road. Anybody else ran into this problem and found a solution? Thanks!!:dunno:
Check your sway bar endlinks, I had the same problem and found the bushings were bad, I ended up just removing my sway bar alltogether, and Im not putting it back on, the ride quality greatly improved, and I dont drive much on the highway so im not worried about doing any highspeed avoidance maneuvers.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
266.2K members
Since 2005
