open hose coming off valvecover??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-01-2013, 11:43 AM Thread Starter
I was wondering if someone could tell me what the hose is coming off the box mounted on the valve cover underneath the intake tube. It mist out a little oil. Is that normal? Can i plug it or run it somewhere else so i wont hear it so much in the truck? It would be the right side valve cover if you were standing in front of the truck.
Thanks,
Zack
stroken733 is offline
post #2 of 6 Old 10-01-2013, 11:49 AM
jvanwalsen's Avatar
It is the crankcase breather, and do not block it off. It was normally routed into the intake. People do a ccv delete so the turbo doesnt get all gunked up with oil. Mine is hanging down in front, drips oil sometimes and has fog like Mist. I am going to reroute it to the back off the truck to take care of the fumes. Look at bobsorings.com he has a site for the delete and how he did it.
jvanwalsen is offline
post #3 of 6 Old 10-01-2013, 11:54 AM Thread Starter
I figured it was supposed to hook up to stock intake. So there's no problem to just extend it and run it somewhere else then?
post #4 of 6 Old 10-01-2013, 11:59 AM
jvanwalsen's Avatar
You are correct, just have to use the right hose material and don't let it get kinked. Probably use metal or plastic fittings at bends and 90s.
post #5 of 6 Old 10-01-2013, 12:03 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well for one i would check to make sure the hole that it originally went into was properly plugged because otherwise you could be sucking in unfiltered air through that. As for the hose yes generally guys do two things with it, either a catch can or vent to the air(usually under the truck)
You have to make sure theres no places in the hose for the oil to collect because then it with create back pressure which is bad. Research CCV re-route before you do it to make sure you do it right
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 6 Old 10-01-2013, 12:13 PM Thread Starter
Thank you guys.
