Fuel bowl rebuild issue - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-01-2013, 07:35 AM Thread Starter
Jerrybizzle's Avatar
Quoted: 21 Post(s)
I rebuilt my fuel bowl last night but when reinstalling the drain one of the four screws is somewhat stripped. It will still tighten decently but what can I do to help it seal better? Rtv high temp silicone? Retap hole for slightly larger screw? What are your suggestions?
Thanks in advance.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #2 of 6 Old 10-01-2013, 11:02 AM
Mearntain's Avatar
Thanks in advance.
If it'll tighten somewhat and it's not leaking, I'd just leave it as is IMO. Wen I rebuilt mine the other day I had something similar happen with my bowl heater screw but all works as it should
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
post #3 of 6 Old 10-01-2013, 12:03 PM Thread Starter
Quoted: 21 Post(s)
I'm putting it back in tonight so that's why I was seeing if there was anything I could do while it's still out to prevent me from putting it back in to see if the seal is good, then worse case find out it's still leaky and have to pull it out again.
Mini maxx
post #4 of 6 Old 10-01-2013, 08:15 PM
timmyboy76's Avatar
its under atleast 60psi, think it'll leak, bud..sorry.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 6 Old 10-01-2013, 09:26 PM
Quoted: 725 Post(s)
Corey@CNCFAB is offline
post #6 of 6 Old 10-02-2013, 07:59 PM
Mearntain's Avatar
You won't have to pull it again, you can get to the drain valve while its attached.
PSN - Rowe
