second guessing myself on egt location....HELP! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-30-2013, 04:01 PM Thread Starter
Hey guys,
I installed my quad pillar over the weekend and tried to find a location for my EGT probe on the drivers header which I could access. I tried on the up-pipe to the turbo but couldn't get my drill in there so only decent location was right in the middle of the drivers side header (between 2 and 3 although not sure of sequence)(had to remove air intake but easy after that).
My question is, where my probe is currently at, it will in theory only be measuring 2 of the cylinders on that side with it being in the middle of the header......will this be sufficient in giving me correct readings? I know all 4 would be ideal but that's where I'm at right now.
Thanks in advance!
Rob73 is offline
post #2 of 13 Old 09-30-2013, 04:12 PM Thread Starter
Dang, can one of the mods move this to the 94.5-97 general forum please.
Rob73 is offline
post #3 of 13 Old 09-30-2013, 04:50 PM
CSIPSD's Avatar
Drill from underneath the truck. Right next to the oil filter...
Too late if you have already drilled but...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 13 Old 09-30-2013, 06:52 PM
Quoted: 17 Post(s)
You put a plug in it, then move it.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 13 Old 10-02-2013, 07:07 AM
DieselManor's Avatar
The proper location is here. Drivers side manifold. Note. this image is orientated so that the front of the truck is to the far right.
David Murphy
DieselManor is offline
post #6 of 13 Old 10-04-2013, 11:19 AM
Will this be the same location on my 2000 7.3 powerstroke? Im fixing to install trans temp, Boost and egt on mine and getting info together for the install.
2005 f250 extcab long bed 6.0 torqe shift (SOLD !!!)
2000 f250 7.3 powerstroke automatic ccsb virgin
05powerstroker is offline
post #7 of 13 Old 10-04-2013, 11:39 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
Yes
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is online now
post #8 of 13 Old 10-04-2013, 02:37 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
you want to install it on the flat spot of the drivers side manifold. you should see an obvious flat spot if you look.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #9 of 13 Old 10-04-2013, 02:42 PM
Quoted: 17 Post(s)
I agree that it's not the most preferred spot but it's not bad. Here's where I have mine installed:
http://www.powerstroke.org/forum/att...0609110711.jpg
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #10 of 13 Old 10-04-2013, 06:32 PM
CSIPSD's Avatar
Not a damn thing wrong with the location pictured. If anything there is more meat there to tap then anywhere else on the manifold. Your good to go in that location. Which is why he pictured it on his website.
Joe
CSIPSD is offline
