Radio works intermittently - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-30-2013, 03:17 PM Thread Starter
Hi, I have a e99 that has intermittent problems with the aftermarket radio. The head unit is an Alpine and I have a Fosgate amp as well, the problem is that sometimes the radio works perfectly, other time the radio will work while you are waiting for the glow plugs and then when you start it the radio will not power up immediately, then it will slowly power up but will not function properly and has no volume. There is no pattern as to when it works or doesn't, it does not seem to be affected by rain or temperature as far as I can tell. Is this a symptom of something else or does it sound like an issue with the radio itself?
rupp49er is offline
post #2 of 3 Old 10-01-2013, 02:12 AM
JSchuricht's Avatar
It could be the radio or a voltage issue. I would start by checking your grounds, both the stock truck ones and at the radio then check the voltage at the radio while it's acting up. I am guessing your seeing <11v which could be caused by a ground, bad connection or a bad battery.
JSchuricht is offline
post #3 of 3 Old 10-01-2013, 02:14 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It sounds like a radio problem, my Pioneer nav radio will do this sometimes when I start the truck.
When you first turn your key on to let the glow plugs warm up the radio starts to boot up, then when you turn your key to start the truck, the power to the radio is interrupted so the radio has to reboot, which can cause issues like this.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
