- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Sponsored Links |
i was thinking to put it in front as a pusher. Last edited by f250power : 06-28-2008 at 07:02 PM. Reason: mis spelled |
Reasons? 6.0 isn't as tough as a 7.3. If you take care of your 7.3, she shouldn't EVER overheat. I've never seen too many 6.0 electric fan clutches having issues cooling, but I've heard grumblings about low speed/idle cooling. I would only recommend for a 6.0 what I stated earlier. Heater bypass and if that doesn't help enough, add a fan. Testing? On the dyno, there was 10hp loss between a new and old stock style fan and clutch. Without a fan, I picked up almost 20hp. Temps without a fan? Max was sitting for 14 minutes in traffic. I hit 230*. Stock gauge hardly hit mid way. Aftermarket gauge stated 230*. Have I pulled without a fan? Yes. Dual axle car hauler with a f150 on it. No issues. If you are pulling 15-20k with your truck, I wouldn't recommend it. And regardless if you keep the stock fan, remove it, or add secondary fan, always test and monitor your truck. |
90-100's in Dallas/Fort Worth. The little bit the fan on the condenser pulls and pushes past the radiator does great. I've moved to a custom built fan setup that I made out of a ford taurus dual fan setup. I even wired up the fans to use the dual speed motors if needed. One VERY important thing I left out. When wiring up a fan, DO NOT DIRECT WIRE ANYTHING. USE A RELAY!!! 30amp Bosch style relays are cheap. DO NOT SKIP THIS!! |
How many cfm does it take ?
| Sponsored Links |
