  #21 (permalink)
Old 06-28-2008, 01:26 PM
CoalRollinRoosterCruiser CoalRollinRoosterCruiser is offline
Freedom Ain't Free
Send a message via AIM to CoalRollinRoosterCruiser
Originally Posted by Southpaw View Post
What happened to the Left Lane thing?
Wasn't that you?
Yeah that was me.
I got my name changed a few weeks ago
  #22 (permalink)
Old 06-28-2008, 05:52 PM
RadarRider RadarRider is offline
Central Scrutinizer
One thing I have had a problem with my Banks/K&N is the gasket surrounding the edge of the rubber. I actually DO check the filter periodically, & I think it was the 2nd or 3rd time I was giving it a look & the gasket had already started coming off. To add insult to injury, the screen mesh on the top had given my knuckle a little slice. So not only does my filter keep dirt out with oil, but it also keeps dirt out with blood!
  #23 (permalink)
Old 06-28-2008, 07:03 PM
alabamafrog alabamafrog is online now
Powerstroke Techie
I have personal experience with both K&N filters and engine dusting.
I have seen a K&N cone filter with tiny dust trails in the intake hoses and signs of light dust throughout the intake. This intake was well cleaned before the K&N filter install and the filter was only installed for about 6 months before we inspected it. I also had a camaro years ago with the K&N, it also was dusted.
My powerstroke engine got dusted by the crappy factory air box leaking and cracks in the intake hoses. It was already dusted when I bought the truck but I didn’t know to look for it. It cost me $4,000 to rebuild my engine and that was doing all of the work myself and shopping around for parts and machine work. I got quotes from &7,000-$12,000 for a new engine.
If you look at it from a logical, physical standpoint a smaller or same size filter that flows lots more air would most likely have to be less dense therefore less restrictive, therefore more dirt could get through. The only way I can see that a filter could flow lots more air and still maintain as good or better filtration is for that filter to be much larger. Also any filter that has to be cleaned, oiled, maintained needs to be owned by a very meticulous and disciplined person.
You folks can do whatever you want but I learned my lesson the hard way, I’ll be using the large $40 DIY filter setup and inspecting my intake regularly from now on.
Be smart, don’t risk it, why risk it?
  #24 (permalink)
Old 06-28-2008, 07:29 PM
Dave Dave is online now
Vikings cheerleaders YUM!
Bigcountrysg has pics of a K&n drop in that got sand sucked thru it. If i get a chance i will take pics of the one i took out of my old truck a little over a year ago you can see sand and dirt holes right through it
  #25 (permalink)
Old 06-28-2008, 07:35 PM
f250power f250power is offline
I'm pretty sure that K&N's after market cone filters are OK. It's their drop in filters that don't fit the Ford factory airbox perfectly. I had never heard that they were prone to get holes in them before, just that they didn't make a good enough fit in the airbox allowing dirt to pass through.
That's definitely not the case for mine. It fits very tight, at least as tight as the factory one I removed.
  #26 (permalink)
Old 06-28-2008, 07:41 PM
Well all this talk about dusting has me paranoid. Sucks I just spent 40 bucks on this thing, what filter should I use then, any suggestions ?
  #27 (permalink)
Old 06-28-2008, 07:46 PM
Powerstroke Techie
  #28 (permalink)
Old 06-28-2008, 07:51 PM
2005F250 2005F250 is offline
If you have a 6.0 buy my AFE. 03+ Stuff for sale
  #29 (permalink)
Old 06-28-2008, 08:03 PM
So is there a problem with the cone type K&N filters or just the drop in, because I can go to advance and get a huge cone for 40 bucks tommorrow.
  #30 (permalink)
Old 06-28-2008, 08:14 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
The majority is telling you to do the DIY intake mod on the 7.3 and for good reasons. If I owned a 7.3 I would do the DIY.
