Can I put my PCM in a different truck? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-30-2013, 12:11 PM Thread Starter
jacobm24's Avatar
Question Can I put my PCM in a different truck?
Ok so long story short, my brother has an 01 7.3 with 300k-ish on it. His batteries died this winter and he wasn't able to change them out for 3 weeks or so (he has a daily driver car). When he finally got around to changing the batts, the truck ran rough and gave an SES code. So far he has changed the plethora of sensors throughout and gotten a new IDM however he still has the issue. He and I think the PCM went bad while it was dead.
Back to my original question, can I put my PCM in his truck to see if that is the issue without harming my PCM?
Thanks for the help
-Jacob
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #2 of 12 Old 09-30-2013, 12:17 PM
GulfcoastStroker's Avatar
If your PCM codes are the same, I believe you can.
2002 F250 CCSB Lariat 4x4 202k
-6637
-Autometer Boost, Pyro, and Trans
-3.5" DP w/ 4" MBRP
-PHP Phoenix
-Amsoil in EVERYTHING
-B&W Turnover
-ARE camper shell
-Detroit TrueTrac rear
-RI Dually's/Plashlights 20"
-Custom front plate bumper
-ProComp 22210, F350 blocks
-315/75/16 Goodyear Duratracs w/ 16x10 8-hole classics
-Bilstein 5100s
-Viper alarm w/Remote Start
-Sony Xplod headunit
-Infinity Kappa 6x8s
-Kicker CVT 12"
GulfcoastStroker is offline
post #3 of 12 Old 09-30-2013, 02:02 PM Thread Starter
jacobm24's Avatar
which codes do I need to look at on the pcm?
thanks for the reply gulf coast. Good to hear from a semi-local lol.
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite IC Boots
jacobm24 is offline
post #4 of 12 Old 09-30-2013, 03:52 PM
CSIPSD's Avatar
Yours will work fine in his... however the pcm is not the issue.
Have you pulled codes?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 12 Old 10-01-2013, 03:45 PM
Justin@DP-Tuner's Avatar
Quoted: 61 Post(s)
The DPC # just has to match. As long as both of your trucks are Federal or they are both California, then it will swap right over.
What was the code the truck threw?
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #6 of 12 Old 10-01-2013, 09:14 PM
Quoted: 822 Post(s)
The DPC numbers do not have to match either. Myself and another member swapped out a 402 and put in 422's. No issue. Actually got the CC light to function though. :thumbup:
Corey@CNCFAB is offline
post #7 of 12 Old 10-01-2013, 09:33 PM
CSIPSD's Avatar
Yup... regardless what some people tell you... so long as your not swapping a 99-2001 into a 2002-2003 or vs your good.
Joe
CSIPSD is offline
post #8 of 12 Old 10-02-2013, 07:04 AM Thread Starter
jacobm24's Avatar
Alright. The swap went fine however the PCM wasn't the problem. I'll tell him to get the codes read and try and go from there.
Thanks for the help guys
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite IC Boots
jacobm24 is offline
post #9 of 12 Old 10-02-2013, 07:38 AM
CSIPSD's Avatar
No way... the pcm didn't fix it?
Bet when you pull that code it tells you right what to replace...
Could have saved about $3-400 in parts swapping.
Joe
CSIPSD is offline
post #10 of 12 Old 10-02-2013, 03:05 PM
Quoted: 61 Post(s)
Yes, the E99 to L99-01(DPC-402 to DPC-422) swap will work just fine. However, in certain cases the DPC# will have to match for everything to work correctly. For instance, you cannot swap a PMT1(DPC-422) and NMC1(DPC-452). Your glow plugs will not work.
What about California models?
DP-Tuner
Like us on
Justin Bochmann
