  #11 (permalink)
Old 06-27-2008, 11:22 PM
lowriderminivan lowriderminivan is offline
if the oil was coming from the injector it would have to pass through the fuel section of the injector first. then you would have oil in the fuel. are you sure its oil coming from the exhaust and not raw fuel?
  #12 (permalink)
Old 06-27-2008, 11:39 PM
jeremy53402 jeremy53402 is offline
I'm going to look at it more but a this point it looked like the cleanist oil ever. Just out of the bottle but wormer.
  #13 (permalink)
Old 06-28-2008, 12:32 AM
outlawdiesel outlawdiesel is offline
Thumbs up fix psd
well there right,ok,your injector has a nozzel and on that nozzel there is a copper washer and if that copper washer is not there or leaking you will get fuel passing throw.after that washer there is a O-ring that seals off fuel from oil and if that is leaking it will have oil and fuel leaking.and so you got this motor from the bone yard.could someone needed some O-rings and take them off the injector?Did you go through the motor be for you put it in?It could be a broken injector cup.what about injector not pushed all the way in and missing hold down bolt.be for starting take out glow plug and turn crank over by hand ,to take out fuel that may be sitting on piston.
  #14 (permalink)
Old 06-28-2008, 04:44 AM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
Originally Posted by jeremy53402 View Post
Are you saying to "pull it" and then run a compression test? or do a test first, then pull the injector? How do you do a test with it out. Remember I'm just a bricklayer. Ii only know what you guys tell me about fords. All my company trucks are Cummings.
Cummings.
  #15 (permalink)
Old 06-28-2008, 07:52 AM
Originally Posted by dhanna6powerstroke View Post
Cummings.
PSD, 3 of them that couldn't make it over 150K before major engine failure.
  #16 (permalink)
Old 06-28-2008, 08:10 AM
Drepka Drepka is offline
Send a message via Yahoo to Drepka
DOH!!!
And he still didn't catch it the second time
Dang those Cummings Turbo Diesels.
  #17 (permalink)
Old 06-28-2008, 08:16 AM
Evil Eye Evil Eye is offline
Slacker Mod
Sounds like a frustrating problem and these guys are trying to point you in the right direction... Good luck finding it!
  #18 (permalink)
Old 06-28-2008, 09:32 AM
I got it the first time..............
  #19 (permalink)
Old 06-28-2008, 12:29 PM
whudya git?
  #20 (permalink)
Old 06-28-2008, 04:58 PM
Got Smoke?
That's what I was just thinking. He'll eventually get it.
