Old 12-17-2005, 10:59 AM
Kodiak74 Kodiak74 is offline
just got new edge evo.
WOW what a difference 400 bucks and 15 minutes makes. Just got my Edge Evolution programer. I can't believe how much more power it unlocks, and the added fuel milage is incredible. can't wait to switch out my exhaust and put an AFE stage II on. I put the evo up on 100 hp for poops and giggles! and had a check engine light come on though, some thing about too much or not enough presssure. but it didn't say what kind of pressure, so i backed it down to the race setting. thanks for the suggestion of the Evo. :burnout
Old 12-17-2005, 11:10 AM
RJacks258 RJacks258 is offline
ses light came on because of too much boost.
Old 12-17-2005, 11:37 AM
how much do i need to worry about that? If I stand on it long enough to humiliate my buddy in his Titan will i damage anything?
Old 12-17-2005, 03:13 PM
02 ford-toy hauler 02 ford-toy hauler is offline
I got edge evoulution and edge juice with attitude and I cant believe the difference either, truck hauls. Also have 4" turbo back exhaust, k&n fipk kit soon to be afe stage 2, banks trans command. Havent tried evolution above tow mode yet.
Old 12-17-2005, 06:11 PM
Worm Drowner Worm Drowner is offline
Quite honestly, I know fellows who ran theirs on race (or higher) without doing any mods, but I don't recommend it. I kept mine on tow until I did my exhaust, then only bumped it to race. I absolutely will not go to extreme until my gauges are hooked up. Yes, I know I'm being conservative, but I'd rather do that than buy a new turbo or worse.
Old 12-18-2005, 07:26 AM
Kodiak74- You don't have to worry too much about excessive boost, becaus when the SES light comes on the MAP sensor is detecting out of range and it defuels a little bit over the stock settings. I'd recommend getting some gauges,(pyro and boost) that way you can watch it all. As far as how much boost is too much, I wouldn't go over 30psi. But the MAP sensor could trigger the SES as low as 20-22psi. Get some gauges and watch it, and then if is triggering the SES at 20psi or so get a relief valve to go inline to the MAP sensor. It will blow off any excess boost past about 25psi. I honestly didn't know what those were for until about a week or two ago. I'm running about 29psi of boost and it kicks on the SES all the time. I ordered one of those valves, the only problem is having to relocate the boost line to the intake manifold.
Old 12-18-2005, 08:06 AM
Rjacks= Thanks for the info. I do have boost and pyro gauges all though i must admit I wasn't sure what kind of pressure to look out for. My temps haven't gone over 600 degrees since i have gotten it. What is the max temp I need to look out for? I don't really drive it that hard but I do get the wild hair once in awhile and want to be sure I don't burn up a turbo. Thanks again for all the info.
Old 12-18-2005, 10:36 AM
That depends on where your thermocoulpler for your pyrometer is, before or after turbo. If it is after turbo(downpipe) max safe would be about 1000 degrees. If it is in your manifold 1300 degrees would be max.
Old 12-18-2005, 11:11 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
My TS chip makes the ses light come on when I crank it up. And you say you have guages but haven't gone past 600 degrees even after putting it on 100 for poops and giggles? Where'd you mount the thermo, in your tailpipe???!!
Old 12-19-2005, 07:02 PM
turbotime turbotime is offline
Send a message via MSN to turbotime Send a message via Skype™ to turbotime
Well Kodiak...I am jealous!!! I was not well aware that there were all the options that there are on the market for a chip when I purchased mine, so when I got the super chips and then found out about this one, I wish that I had just saved my money for the one that you got. But, that is life, I should have done my research. Lesson learned here and I will someday upgrade to the Edge. Glad to hear that you are taking it safe and still enjoying it!
