testing for weak hpop - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-28-2013, 11:45 PM Thread Starter
hey guys, just looking to see if i could get a few pointers on what test to run and look for to see if my hpop is taking a dive on me.. i got a scan tool so i can monitor and record live feedback on icp... thanks in advance
2002 7.3 with the basics.... 4in tb, cold air, dp tuned, autometer pillar... feel free to make donations
fl-diesel is offline
post #2 of 14 Old 09-29-2013, 01:29 AM
JSchuricht's Avatar
You should log ICP and duty cycle then take it for a drive at WOT.
JSchuricht is offline
post #3 of 14 Old 09-29-2013, 01:34 AM Thread Starter
i did 1 run on my 120 tune before coming to work... beginning around 2115 psi @ 52%, halfway through i was at 1860psi @ 60%, and right at the end of my run i was at 2132psi @ 71%
post #4 of 14 Old 09-29-2013, 07:12 AM
timmyboy76's Avatar
you should test in "stock" setting.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 14 Old 09-29-2013, 07:30 AM Thread Starter
Tested in stock setting I didn't drop below 2750psi and didn't exceed 40%..... With the 120 tune I started at 53% @ 2036psi, at the end of my run I was at 78% @1890psi... Truck was warm in both occasions... And threw a p1212 code... Just got done testing again
post #6 of 14 Old 09-29-2013, 08:11 AM
jesilvas's Avatar
Quoted: 2 Post(s)
I'd say it's a little weak. You could have a bad ICP sensor giving an off reading. If the connector is oily, replace it anyway.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 14 Old 09-29-2013, 08:45 AM Thread Starter
i replaced the ipr about 500 miles ago... and if i was getting false readings wouldnt it read way off on the stock tune also?
post #8 of 14 Old 09-29-2013, 09:02 AM
timmyboy76's Avatar
from the looks of it, the stock #'s are fine, but the hpop just cant keep up with demands in higher hp settings...upgraded hpop will cure that.
post #9 of 14 Old 09-29-2013, 10:02 AM
Joel's Avatar
Quoted: 10 Post(s)
Is this not one of the situations where old and tired injectors or injector o-rings could be at fault?
Because mine acts the same way, only I can hit 99% duty cycle and drop down to 1600 psi
My ICP and IPR sensor/regulator were recently replaced.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 14 Old 09-29-2013, 01:13 PM
Hauling my new 5th wheel camper i had the same code-so far i am changing the ICP this week as the sensor is covered in oil. Plan on taking the camper out end of the week to see what happens. Hoping it ends there.
How do you like your DP-Tuner? I'm seriously thinking of going that route soon, especially with the data you can get running down the road.
mkfan17 is offline
