swapping '99 van engine into L99 SD - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-28-2013, 06:36 PM Thread Starter
Question swapping '99 van engine into L99 SD
Hi I just bought a '99 van engine minus the turbo to replace my tired, dusted engine. What needs to be swapped over from the old engine to make this work? I have heard that some brackets may be different and that the right exhaust manifold is different in the van. I will be using my own hpop and recent injectors for this new engine. thanks
lght1 is offline
post #2 of 3 Old 10-02-2013, 08:48 PM Thread Starter
hi ttt update: from other sources, I have learned that the van and SD share the right side manifold part number but the left is a different stock number. some say the oil filter housing is different and yet others say the oil cooler is different as well. has anyone done this swap and if so, what definitely needed to be changed out ? thanks in advance
lght1 is offline
post #3 of 3 Old 01-02-2014, 05:39 AM
I just did one in my 02 superduty. I changed the manifolds although one of them was the same. The oil cooler is different. the valve covers. just the easy bolt on stuff!! doing one now with a friend but its a 6.0 e series to f series.. looks more complicated
northern1 is offline
