First start help needed. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-28-2013, 05:15 PM Thread Starter
Redrock2000's Avatar
Quoted: 2 Post(s)
My 2000 has started to give me a little problem at first start of the day. I hope it's the glow plugs but with 185k on the odo I don't know. What happens is when I first start it it idles with a miss. I let it warm up to normal temp and drive away still missing then when I give it about half throttle it clears up and doesn't happen the rest of the day unless it gets cool. I'm taking a 2500 mile trip in a week and I'm a little concerned since I'm going north to cooler weather. Haven't been able to do anything to it yet. I plan on cleaning the ebpv tube and sensor next week and whatever else I can.
I don't care how they do it in Japan
Redrock2000 is offline
post #2 of 5 Old 09-28-2013, 05:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What oil type/weight and how many miles on it?
I would ohm out the GPs, but mainly check the GPR and possibly battery voltages.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 09-29-2013, 06:46 AM Thread Starter
Quoted: 2 Post(s)
15/40 Rotella t dyno with about 1500 miles on it. I'm going to try and check the gp system this week. Thanks
post #4 of 5 Old 09-29-2013, 10:58 AM
Mearntain's Avatar
Another thought, have you checked your oil for contamination? As in fuel or coolant in there?
Do you have any way to read data like with a AE scanner or torque app?
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
post #5 of 5 Old 09-29-2013, 11:32 AM
blue99stroker's Avatar
Quoted: 246 Post(s)
if the plugs/relay are original they need to be changed.
also check your icp sensor. i there is oil coming through it change it, you could be getting innacurate oil pressure as well.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
