Fuel bowl rebuild - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-28-2013, 02:04 AM Thread Starter
Mearntain's Avatar
Fuel bowl rebuild
I would like to reseal my fuel bowl later today and have permatex high temp thread sealant that I was going to use where required. I'm reading some things saying that it won't cure for over 24 hrs but see 72 hrs on the package. How long should I expect my truck to be down before it will be good to go without leaking for those of you who have used this? Is there anything better that will cure a lot faster?
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
post #2 of 18 Old 09-28-2013, 05:09 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
There is nothing in the fuel bowl to use permatex on. It install o-rings and rubber sleeves. You need to order the kit from dieselorings.com
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 18 Old 09-28-2013, 10:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Do not use sealant anywhere
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 18 Old 09-28-2013, 10:58 AM Thread Starter
Mearntain's Avatar
I bought my seal kit from dieselorings and in his instructions, it says to use diesel fuel rated thread sealant on all NPT threads
PSN - Rowe
post #5 of 18 Old 09-28-2013, 11:12 AM
timmyboy76's Avatar
that might refer to the oring plugs on the rails and the hpop threads. Nothing on the fuel bowl though, needs sealant. the orings and parker sleeves take care of any leaks.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 18 Old 09-28-2013, 11:23 AM Thread Starter
Mearntain's Avatar
Sounds good. I posted this on PSN too and it seems like no sealant is the consensus. Thanks everyone for the replies
PSN - Rowe
post #7 of 18 Old 09-28-2013, 11:34 AM
schlutzer's Avatar
Quoted: 18 Post(s)
I was wrong. Blame the lack of sleep. I misread and thought you were gong to deal up leaks lol.
In his instructions, it shows where to use a sealant, I would probably follow them
post #8 of 18 Old 09-29-2013, 11:13 AM
Jerrybizzle's Avatar
Quoted: 23 Post(s)
Did you end up doing the rebuild yet? Just wondering how long it took you and if you have any additional tips or things you learned? I am doing mine today or tomorrow.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #9 of 18 Old 09-29-2013, 11:21 AM Thread Starter
Mearntain's Avatar
Yep, I did it yesterday, 4 times thinking I had a problem. The whole rebuild went easy, lacquer thinner was the key to removing the Stock PTFE inside. Where I thought I went wrong was when I would prime the bowl, my pressure would maintain 65 psi, and then it would drop once the pump cut off. I thought something was wrong so kept taking it apart to try to find the issue, but come to find out its supposed to do that. Realistically it shouldn't take much longer than an hour. I spent extra time on mine since it was so dirty, gross isn't even a strong enough word to describe how mine was. I've got 321K and I'm pretty sure this was the first time it was ever apart.
PSN - Rowe
post #10 of 18 Old 09-29-2013, 11:29 AM
Quoted: 23 Post(s)
thanks. Sounds good. Hopefully mine goes smooth as well.
Mini maxx
