Key Fob and lights - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-27-2013, 06:22 PM Thread Starter
Key Fob and lights
I don't know why I just noticed this, but on my 2012 F250 work truck when I unlock the doors, the taillights and brake light illuminates and when I lock it they flash.
On my 2002 when I unlock the doors, the dome light and the third brake light illuminates, nothing else and when I lock it the doors lock but nothing else unless I press it twice in which it honks.
Is this normal or is something screwy with my truck?
I don't like that the lights don't like up when unlocking, especially at night.
Thanks
Dave
lexinator02 is offline
post #2 of 6 Old 09-28-2013, 08:14 PM
thetechie01's Avatar
Totally normal. Don't think they started having the parking lights come on till the '08 body style change
thetechie01 is offline
post #3 of 6 Old 09-28-2013, 08:27 PM
Long Member
TMAG6.0's Avatar
On unlock my '04 map/dome light and running board lights come on. Dont know about the tail lights and such. Never paid attention
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #4 of 6 Old 10-01-2013, 05:37 AM
broncomitch's Avatar
Dose anyone know why the fobs won't work on a 99 SD?
I want to do the key fob and wire in running board lights into the system.
I was just going to run the lights up to the map/dome light.. So when it unlocks they come on and the door opens they come on.
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #5 of 6 Old 10-01-2013, 05:52 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Its not just a 99 thing it has to do if you have keyless entry installed on your truck. To test if you do turn the key on and off like 6 times in 10 secs and the doors lock then unlock automatically signaling you have it installed.
If you want to wire running board lights ill save you time tracing wires, tap into the wire that runs along the drivers side floor wire bundle that is blue with a black tracer
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 6 Old 10-03-2013, 03:20 PM
Yupp, it's setup for em!
Good idea about the door lights!
This project is on!
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
