Closed Thread
  #41 (permalink)
Old 06-27-2008, 10:09 AM
tubular031 tubular031 is offline
next change I do I am going to only change the crank case then after 500 miles pull a sample off the dip stick and also pull a sample out of the res. I would be willing to bet that both will be the same...
  #42 (permalink)
Old 06-27-2008, 10:13 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
THIS IS THE MOST ENTIRELY RIDICULOUS CRAP IVE EVER HEARD OF , NUFF SAID
  #43 (permalink)
Old 06-27-2008, 10:28 AM
blowinsmoke4life blowinsmoke4life is offline
Send a message via AIM to blowinsmoke4life
whether the top end oil change sounds like bs or not, it seems like common sense to change the oil going thru ur injectors especially if u want ur truck to run long
  #44 (permalink)
Old 06-27-2008, 10:40 AM
people will believe anything they hear on the internet
  #45 (permalink)
Old 06-27-2008, 10:44 AM
i had a feeling someone would say that lol
  #46 (permalink)
Old 06-27-2008, 11:04 AM
That is what i thought. thanks scuffy!
  #47 (permalink)
Old 06-27-2008, 11:13 AM
sorry , thats just the way i see it , if i wasnt at work i may have more time to explain, but vreading this thread ,it has been covered
  #48 (permalink)
Old 06-27-2008, 12:42 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
I just read this thread all the way through. What a worthless waste of time. Both the reading and this magical "top end" oil change.
  #49 (permalink)
Old 06-27-2008, 01:26 PM
Howard i cant believe you arent gonna jump on this and do it to your truck, the way i see it , if i run amsoil and the bypass filter system, do the top end oil change every 50,000 miles i should be able to go at least 100,000 miles on the next oil change , what a miracle
  #50 (permalink)
Old 06-27-2008, 01:48 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Will you explain more when you get off work later on Scuffy.
Closed Thread
