uh oh...p1211 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-26-2013, 02:34 PM Thread Starter
EvansF250's Avatar
uh oh...p1211
Getting on it hard this morning and got a p1211 low/ high desired icp pressure. Ive noticed that I have had a power loss, have to get in throttle little more then I used too to even get the truck moving. I was watching my throttle position %, icp pressure and ipr %. At 80% throttle the ipr % jumps to 45% and icp will go from 2600 psi to 2000 psi, and sometimes all the way to 1000 psi and I still dont have it wot. I have tried to get it above 2600 psi but it wont, just falls down to 1000psi. I have had no issues with starting hot or cold, no fuel in oil and loss of power with lots of black smoke in o.d. when I stomp on it. i feel like its my HPOP but would like to know what else it could be.
2005 Ford F250 Harley Davidson Edition
D.D.
EGR delete, ARP Headstuds, Edge Insight with Egt and FP, blue spring kit, 4in mbrp tb exhaust with 6 inch tip, 35 " Discover STT Tires, Sinister Coolant Filter, ELC Cat-1 coolant, Mobil 1 5w-40, PHP ATLAS 40, SCT Tuner w/ Gearhead Tunes, Warren 155cc/ stock, STC Fitting Update
EvansF250 is offline
post #2 of 5 Old 09-26-2013, 03:46 PM
Justin@DP-Tuner's Avatar
Quoted: 46 Post(s)
ICP drops to 1000psi?! What is the duty cycle like at that point?
How many miles are on the HPOP?
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 5 Old 09-26-2013, 04:09 PM Thread Starter
EvansF250's Avatar
Not sure, I keep the icp psi on all the time but not the duty cycle. Ipr duty cycle I turned on after I saw it go 1000 psi. Then I ran the truck again and got the pressure drop to 2000 psi / 45% ipr, didnt push it further because I dont want to damage the truck. I figured that was enough beating on it. The hpop has 253000 miles on it.
D.D.
post #4 of 5 Old 09-29-2013, 02:19 PM Thread Starter
EvansF250's Avatar
Bump, bump
D.D.
post #5 of 5 Old 09-29-2013, 02:49 PM Thread Starter
EvansF250's Avatar
A p1211 comes on when the truck at WOT cant maintain above 2100 psi on the ICP, from what read in a forum. Other than a weak hpop, what else would pressure to drop that low or keep dropping at WOT?
D.D.
