sudden death - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-25-2013, 10:47 PM Thread Starter
shovelth's Avatar
sudden death
my 7.3 is old and tired but is a runner it started shutting down unexpectantly will start right back up runs a few minutes and dies at a higher idle it stumbbles a bit but stays running. no miss just a complete shut down fuel filter has been changed but no change do not suspect injector drive mod because it's not missing any ideas what i should check next??????
shovelth is offline
post #2 of 14 Old 09-25-2013, 10:52 PM
Have you checked the oil recently?
Psd715 is offline
post #3 of 14 Old 09-25-2013, 11:17 PM Thread Starter
shovelth's Avatar
full and mid-range oil pressure watching all gauges all normal.
shovelth is offline
post #4 of 14 Old 09-25-2013, 11:38 PM
444 ci's Avatar
check your cam position sensor
444 ci is offline
post #5 of 14 Old 09-26-2013, 12:01 AM
schlutzer's Avatar
Quoted: 18 Post(s)
yup that's almost guaranteed to be the Cam Position Sensor.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 14 Old 09-26-2013, 12:42 AM
CSIPSD's Avatar
Fuel pump...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 14 Old 09-26-2013, 08:17 AM Thread Starter
shovelth's Avatar
k thanks will let you know the turn out but, should'nt that set off the check engine lt. ???
shovelth is offline
post #8 of 14 Old 09-26-2013, 08:25 AM
I would suggest the cps also. When I purchased my 7.3 in 01 I had the same problem. Ford installed 3 cps and then there was a recall on the cps. I was reimbursed for the first three cps I brought and Ford put in the latest and greatest cps and no more problems.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #9 of 14 Old 09-26-2013, 10:46 PM Thread Starter
shovelth's Avatar
this is a 94 7.3 and does'nt have a cmp sensor
shovelth is offline
post #10 of 14 Old 09-26-2013, 11:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Well then you need to post in the correct section, because you post in the 99-03 section your going to get advice for the 99-03 trucks...
Being a 94 you need to provide more info otherwise nobody can help you. We don't magically know anything about your truck. 94 is a bastard year and there is 3 very different possible 7.3's in that year. 7.3 idi N/a, 7.3 turbo, and 7.3 powerstroke completely different engines.
