Coolant flush issue. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-25-2013, 08:03 PM Thread Starter
blue72's Avatar
Feedback Score: 5 reviews
I looked at several write-ups and most recommended removing the coolant plugs from the block. Has anyone else had issues getting the coolant plugs out of the block? I actually damaged both plugs trying to get them out. I wonder if the previous owner used loc-tite on them or something?
Other than that my coolant flush went well, should be the last flush ever since I put in some ELC. Just wondering if anyone else has had issues with those plugs.
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #2 of 6 Old 09-25-2013, 08:53 PM
KCCO!!
kells17's Avatar
Mine were a beast...I used longer extensions for better leverage and out they came...replaced with fumoto's and now it's quick and easy...
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 6 Old 09-25-2013, 08:58 PM Thread Starter
blue72's Avatar
I cracked one and broke the side out of the other... they are not coming out now without a drill. Luckily the damage to the plugs did not effect the integrity of the seal. I even used some penetrating lube, but they would still not come out. Then they finally cracked/broke.
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
blue72 is offline
post #4 of 6 Old 09-25-2013, 09:03 PM
KCCO!!
kells17's Avatar
Those bad mammer jammer's were in there eh? I would definitely go with fumoto's when you get them out...very easy and the juice goes where you want it..
VA Strokers
757 Diesel
kells17 is offline
post #5 of 6 Old 09-26-2013, 02:21 PM
I guess I was lucky. Mine came out fairly easy when I did the flush and change to ELC.
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
post #6 of 6 Old 09-26-2013, 03:13 PM Thread Starter
blue72's Avatar
I was surprised too... never heard of anyone having issues with them before. I researched and read several write-ups and there was nothing mentioned about block plug issues.
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
blue72 is offline
