Reverse lights not working - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-25-2013, 02:34 PM Thread Starter
I have a 1999 f250 4x4 7.3l single cab long bed. I put a flat bed on it a while back and now my reverse lights stopped working and I also had the transmission built. So I'm not to sure when thye stopped working or if it was because of any of that. But I've checked the fuses and the lights are fine but for some reason when I'm in reverse I have no reverse lights. I've heard of the switch on the transmission but don't know anything about it. Any pointers will help.
Thank you
Flashflood394 is offline
post #2 of 7 Old 09-25-2013, 04:15 PM
belz's Avatar
Quoted: 78 Post(s)
On the side of the transmission where the linkage connects is an adjustable switch. I think that's what they are talking about. Chock the wheels and put it in reverse. Then adjust that until the lights come on. Unless there is another one on the column that's the only one I know of.
Belz
CPA Director
belz is offline
post #3 of 7 Old 09-25-2013, 04:28 PM Thread Starter
Ok I know where that's at, I looked at it and the way it looks to me is a piece you can turn in the middle with a line through the center then right on the outside of that there is a little white ring, and it also has a small line in it then a bigger one that looks like the one on the main piece you turn. The main piece is lined up with the smaller dash on the white ring. Is what your telling me is that it is suppose to be lined up with the bigger line. Or should I just try it an see if it works?
And also do I have to take it off or anything to adjust it or should it move right now if I stuck a flathead in it
post #4 of 7 Old 09-25-2013, 04:30 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
As long as the the gear select indicator is on the correct letter (P,R,N...etc) than you don't need to adjust it at the column. Just adjust at the trans like indicated in the post above me.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 7 Old 09-26-2013, 07:32 PM Thread Starter
Ok so I just got under my truck. Had the key in the on position but not started. Put the truck in reverse and when I looked under it the two dashes were not lined up so I lined them up, but all that did was put the indicator on the dash from the R (reverse) to N (neutral). So either I'm not getting what your saying and doing it wrong or it's something else possibly? I sure appreciate all the help, and pointers though because eventually I'll get down to the reason why. I took a few pictures but I don't know how to upload them
post #6 of 7 Old 09-26-2013, 08:08 PM Thread Starter
I also have my lights wired through a junction box, that's how semi's and big trucks are weird and it's the cleanest way to have them all wired to my flat bed. But I believe when we did it we used the trailer plug wires to do it. So idk if that could have something to do with it or what. But I've also heard of a back up light switch on the transmission, so I googled it and I'm not sure if it's for my year truck or what but all it looks like is two little prongs the plug into it somewhere on the transmission, could that be it or do I not have that?
post #7 of 7 Old 09-28-2013, 04:08 AM
belz's Avatar
Quoted: 78 Post(s)
Is it the factory reverse lights that aren't working or an extra set that you have hooked up? Did you re wire the oem lights to a junction box? Your last post had me a bit confused.
Belz
CPA Director
belz is offline
Tags
flat bed , lights , reverse
