Air horn activated by ignition? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-25-2013, 10:56 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Being the thrifty and experimental person i am i was looking into alternative security systems than the over priced and known systems. I believe good old ingenuity is way better than a system you can buy.
So my idea is to wire my air horn to the ignition so that unless the switch(conveniently hidden) is off, you turn the power to the ignition, by way of the key(miraculously obtained from my pocket) or by a screw driver jammed in the ignition it will blast the horn continuously while it is running.
That coupled with my clutch kill switch (found here) will i hopes frustrate the thief enough that he takes off. And since i live in an apartment complex, having air horns blasting is sure to bring attention to my truck enough that someone would call the cops if anything to complain about the noise.
Im also kind of toying with the idea of wiring it to the map lights circuit as well so that they cant even get into the truck without the horns blasting but i cant think of an easy way to have it disengage so i dont blast myself getting in.
Just thought id share my plan and maybe give you guys some ideas.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 23 Old 09-25-2013, 06:25 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I have an idea thats even better as far as security.... well maybe.
You can get fingerprint deadbolts for your house I have one. Ours can have up to 25 people fingers saved. I'm curious to take one apart and find a way to put the guts inside the truck door, then make the actuator that moves the deadbolt, just move the lock instead.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 23 Old 09-25-2013, 06:33 PM
codyryan07's Avatar
That would be pretty interesting.. it would take a good amount of knowledge with basic servos and what not to make it work..
I like the idea of the air horn blasting too.. I've thought of something similar since we live in duplexes. Although its not a high crime area, I've seen a few shady folk walking through that I tend to eye ball.. I think it would be as simple as wiring an extra valve control solenoid in to your key on power with a switch between.. just remember to hit the switch before leaving or you'll
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #4 of 23 Old 09-25-2013, 06:50 PM
Quoted: 17 Post(s)
Downfall to the fingerprint is I could see those easily failing especially being exposed in the elements. If you can get you hands on die packs you could wire one of those in to your alarm circuit so if they try to Hotwire it then the dye pack will explode. They will be easier to catch by the authorities.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 23 Old 09-25-2013, 07:00 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Same here its iowa after all but still you never know what pos might try something. And it would be even easier than would just need to splice into an ignition on circuit running to the (+) side of the solenoid valve and there you go. But yea im sure ill get myself more often than not but oh well
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 23 Old 09-25-2013, 07:34 PM
Joel's Avatar
Quoted: 10 Post(s)
I've had my air horns hooked up to my alarm for years.
Best bet is to buy the cheapest possible alarm and just wire it into that.
Could get keyless entry and remote start out of the deal if you wanted to
But if you really want o do it on the cheap, try using the fuel pump circuit.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 23 Old 09-25-2013, 08:00 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
I thought about using the fuel pump and i like how it shuts off after 20 seconds so by then they are gone or if they start it theres no shutting it off
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 23 Old 09-25-2013, 10:10 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Fuel pump shutoff is great on a gas engine, but you run the risk of damaging your injectors since they need fuel to lubricate... expecially if the thief kept trying to start the truck.
I've tossed the idea around of having the PCM hooked up to a switch, but that's a sensitive piece. Maybe IDM but really a hidden switch for the Clutch pedal sensor is a great idea. For the auto guy's, your truck has the wiring for this and it is live, there is a dummy plug from factory.
Another idea would be the neutral safety switch, cps ( if anybody wants to mess with that circuit), ICP ( again maybe risky), or the start wire from the ignition.
post #9 of 23 Old 09-25-2013, 10:33 PM
mazsecond's Avatar
Feedback Score: 4 reviews
Have any of you guys ever heard of revelco? Thats what I have on my truck and I love it. It saved my current truck once already and saved my old 6.0 (totaled) TWICE! I was sold on it and had to get it in my current truck when I bought it. Its about $500. I still love the idea of the train horn alarm though, now I just need some train horns...
I'm not exactly sure how its wired but this is from their website:
"The circuits interrupted by the RAVELCO may vary from application to application. Typically, they would include the electronic fuel pump, the ignition circuit, the starter circuit or even the computer."
"All electrical connections are made in the engine compartment of the vehicle and are connected in and through the factory wiring harnesses. Since there are no exposed wires, a properly-installed RAVELCO is virtually impossible to detect and very time consuming to trace because all the wires are the same color (black). Even trained, mechanics have called our offices to question the location of the RAVELCO hookup on a vehicle."
Mike
mazsecond is offline
post #10 of 23 Old 09-26-2013, 05:08 AM
Macon's Avatar
I don't trust biometric things. I've logged into several computers with fingerprint log-ons by doing nothing more than repeatedly pressing my finger on the scanner. They're only as good as the software supporting them, and manufactures always try to save costs...
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
