35's on leveled f250 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-25-2013, 08:40 AM Thread Starter
What do you guys think? I have 33s on my F250 now and I am thinking about going with 35s and was wondering if there would be any clearance issues? Also I'm debating on some 20" wheels off from a newer King Ranch to go along with it. The truck is just leveled and has F350 blocks in the back. I just have the 16" factory wheels at the moment. Also was wondering if the backspacing is different with the newer than my 2001 trucks wheels?
Donman is offline
post #2 of 9 Old 09-25-2013, 09:01 AM
Joel's Avatar
Quoted: 10 Post(s)
The back spacing is different and will cause issues.
Better option is to just buy some new wheels that you like.
35's should fit though, you might have minor rubbing issues.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 9 Old 09-25-2013, 12:33 PM
Quoted: 28 Post(s)
Yes you will have issues, the coiled front end allows for the wheels to be tucked in a bit more where ours have leaves and the tires will rub on the leaves at full turn. 33's on newer wheels would probably work but not positive.
I put my dads wheels off his 11' on my 2000 and they rubbed on the leaves and on the front mudflap. If i had the newer front end i would have been fine. Would love to do the swap some day.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #4 of 9 Old 09-25-2013, 03:58 PM Thread Starter
Ok thanks. Yea honestly there's not a ton of aftermarket wheels that I like, I guess I'm a little old school and just like wheels that come off some of the newer super duties. I just think that 35s on my stock 16s mightobit look a little iffy.
Donman is offline
post #5 of 9 Old 09-25-2013, 05:46 PM
codyryan07's Avatar
A lot of people run the newer wheels on our trucks.. it just requires a spacer to help correct the offset.. most run a 2 inch spacer, and I would strongly suggest running a high quality steel spacer (Fred Groeske comes to mind) over the cheap ebay aluminum ones. With the wheels in that offset, with the spacer, you might have some minor rubbing issues and will need to trim the front valence and the rear fender liner.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #6 of 9 Old 09-25-2013, 06:12 PM
Zaairman's Avatar
Quoted: 12 Post(s)
35s will fit but they will need some trimming of the inner fender to fit.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #7 of 9 Old 09-25-2013, 06:33 PM
Quoted: 822 Post(s)
No they won't.
35's with newer OEM wheels will rub the leafs. You will need 2" spacers if that's what you want. You'd be better off getting aftermarket wheels with offset correction to run a 35" tire than to get spacers though.
I'm sure many of us on here have read spacers are bad, but who out there can actually claim they have ran spacers with quality Timken bearings and can 100% attribute that is was the spacers fault and not other factors that could have also contributed to the bearing fail like ball joints, steering arms loose, alignment, out of balance tires, etc.
To my knowledge, Fred Goeske has no lawsuits pending due to bearings failing from 1000's of his spacers sold.
Corey@CNCFAB is offline
post #8 of 9 Old 09-25-2013, 06:49 PM
Ford94stroker's Avatar
Quoted: 2 Post(s)
my 05 f350 is leveled and I run 35's, the only time it rubs is on the drivers side when I got the wheel cranked all the way to one side. it's minimal so I trimmed a tiny bit and I'm good. I run the XD revolver with a slight offset 18" rim.
Ford94stroker is offline
post #9 of 9 Old 09-26-2013, 03:06 AM
heisman01's Avatar
Quoted: 53 Post(s)
WheelAdapter.com > Wheel Spacers
This is what everyone's talking about, 370 for spacers made from steel isn't a bad deal.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
