Highest safe boost pressure. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-23-2013, 09:25 AM Thread Starter
BrodieBiking's Avatar
Hey guys, particularly ones with GTP38r's.
What is the highest boost pressure you can run without wrecking anything?
Right now, i'm getting around 25-27 lbs if i push it.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #2 of 15 Old 09-23-2013, 09:56 AM
It says the exact same blurb on every website that sells the 38r: "Maximum recommended boost level is 40 psi"
Greenman01 is offline
post #3 of 15 Old 09-23-2013, 12:10 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
maybe you can stretch that out a little more by adding a billet compressor wheel, but not much more than 40.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 15 Old 09-23-2013, 01:02 PM
Quoted: 27 Post(s)
Hey now, Who in their right mind would waste any time looking this info up on their own!!
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #5 of 15 Old 09-23-2013, 01:40 PM Thread Starter
Sorry, let me rephrase this question. What is the max safe boost pressure you can run on a 7.3 with blowing out the head gasket ect...
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #6 of 15 Old 09-23-2013, 01:58 PM
Quoted: 27 Post(s)
This is a completely different question having nothing to do with any turbo.
I personally would not try to surpass 40 PSI without springs, valves and probably studs too. Honestly if i was pushing 35 PSI consistently i would do springs and valves but i like my stuff to last and i like the piece of mind. Some will say you are fine especially at 35 but going past 40 and you will want do springs, valves, and studs. Its not a must do but its a good idea.
If your only running a 38R i would not upgrade these items unless you plan on going bigger in the future.
I do not have personal experience with this but i do a lot of reading.
post #7 of 15 Old 09-23-2013, 02:03 PM Thread Starter
Perfect, what I was looking for.
Thanks.
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #8 of 15 Old 09-23-2013, 02:11 PM
Quoted: 27 Post(s)
Thanks.
Like your truck BTW. Not exactly what many others would build but its different. Dont think I have ever seen 24.5's on a 1 ton chassis.
post #9 of 15 Old 09-23-2013, 02:14 PM
Quoted: 249 Post(s)
tuning plays a big role in the longevity of these motors/trucks as well.
post #10 of 15 Old 09-23-2013, 02:17 PM Thread Starter
Haha, thanks. It was used as our business truck for a while, mainly because it was dock level and we could throw a couple pallets in the back. Now it's just a daily driver.
2002 F350 CCLB DRW
ZF6 SWAPPED!
