synthetic fluids in differentials? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-23-2013, 03:30 AM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
getting my 99 set up for my main tow rig/work truck. I have a 30 ft dual tandem 20,000gvw g/n I haul tractors, hay farm equipment with. it has 200k on it. will it be ok to switch over the front& rear diif's over to semi syn or full synthetic? and what's weight 85-140???? any input will be appreciated
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 16 Old 09-23-2013, 11:14 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
rear requires FULL synthetic. 75w-140. make sure it has limited slip additive in it or add some.
front doesn't require synthetic but you can put it in if you want. that one is either 75w-90 or 80w-90 cant remember right now.
oh and i would also flush the transfer case while your doing maintenance. the trans case is often overlooked, when i flushed mine it was way overdue from the previous owner never doing it.
2 quarts of atf, synthetic atf if you want for the trans case.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 16 Old 09-23-2013, 12:14 PM Thread Starter
Quoted: 2 Post(s)
I guess I didn't realize the rear required synthetic. I already did the transfer case, it was nasty!!!
post #4 of 16 Old 09-23-2013, 12:43 PM
hansel's Avatar
Quoted: 97 Post(s)
I use Mobil1 (SYN) 75W-140 which has the friction modifier already in it.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 16 Old 09-23-2013, 01:15 PM
Quoted: 258 Post(s)
ya the trans case is always overlooked.
i used mobil 1 as well. got it at napa 12 bucks a quart i think.
post #6 of 16 Old 09-23-2013, 01:51 PM
Quoted: 784 Post(s)
IMO I think you would benefit greatly by an oversized rear diff cover with all the towing you do. I use Amsoil and I feel it does make s significant difference. Although I run Amsoil in the engine also, I'm still not quite sold on it for that. I'm getting ready to send out the 10k oil analysis here pretty soon.
Corey@CNCFAB is offline
post #7 of 16 Old 09-23-2013, 01:59 PM
Quoted: 27 Post(s)
You run ATF fluid in your T-case? Hows that work out for ya? Why not just a synthetic gear oil?
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #8 of 16 Old 09-23-2013, 02:27 PM
Quoted: 784 Post(s)
Because that's what it requires.
post #9 of 16 Old 09-23-2013, 02:33 PM
Quoted: 27 Post(s)
So does a manual trans require ATF also? Dont have my manual in front of me or else id look.
Is the T case gear driven or chain driven?
I just cant imagine an ATF fluid would be better for any unit that is gear driven...Or do they say ATF fluid cause most of these rigs came with autos and if the seal between the tranny and T case goes you want the same fluid type so they dont ruin each other.
Thanks.
post #10 of 16 Old 09-23-2013, 02:46 PM
Quoted: 784 Post(s)
Thanks.
Its ATF because of the metallurgy doesn't require the gear oil of old. Also they have an actual gear pump in them to lube everything instead of relying on the heavy oil to "stick" to the gears n such to get circulated around. They are chain driven.
My transfer case has 416k miles on it. So I'd say use the ATF. Lol. BTW the NP 271/272/273 cases are rated at 7890 ft/lbs of torque. Yes, you read it correct, pretty much bulletproof.
