6.0 tranny cooler upgrade pissin me off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-22-2013, 05:09 AM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
got everything done and in place, went to lowes in the plumbing section and bought 3/8-1/2" barbed fitting. couldn't find any 1/2" rubber transmission line at the parts stores, so I purchased 1/2" hydraulic line. the fittings from lowes that are supposed to be 3/8 and 1/2" well needless to say, the fittings are not a true 1/2" or 3/8" slightly smaller don't fit snug into the hoses. this is pissin me off!! sounds like I may have to go to lowes and buy a bunch of couplers and screw them together to get my 3/8 to 1/2" anybody have any suggestions?
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 6 Old 09-22-2013, 07:56 AM
Quoted: 3 Post(s)
worm clams
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 6 Old 09-22-2013, 06:32 PM
hansel's Avatar
Quoted: 100 Post(s)
You don't have a hydrualic store near by? That is where I got my fittings.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 6 Old 09-22-2013, 06:40 PM Thread Starter
Quoted: 2 Post(s)
I ended up using a steel 3/8-1/2" coupler with brass barb fittings on each end till I find the correct 3/8-1/2" steel barb fittings. test drove tonite, unbeliavible how much difference there is between the ingoing/ outgoing line temps. I'm happy with upgrade
post #5 of 6 Old 09-23-2013, 12:48 PM
hansel's Avatar
Quoted: 100 Post(s)
I never had a temp gauge when I had the old small arsh stock cooler, but my temp has never seen more than 152* and that was pulling my Keystone Laredo which is a 8,000lb+ camper.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #6 of 6 Old 09-23-2013, 02:36 PM Thread Starter
Quoted: 2 Post(s)
that's great to know! I'll be hauling 10-18,000 a few times a month. great piece of mind. I changed transfer case fluid while I did the tranny ( trans has a drain plug) fluid was all sorts of nasty!!
