damn white smoke - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-20-2013, 07:17 PM Thread Starter
damn white smoke
02 f250, 7.3 123k. Truck get's started every two to three days. As of late, when I start it, let it run a minute or so then take off, it's smokes out half the street. white smoke. Have read that it's unburned fuel at the top of the piston. Sure is a lot of unburned fuel. This only happens 1 to 2 times out of \every ten start ups. any ideas? thanks.
sean andreano is offline
post #2 of 2 Old 09-21-2013, 08:30 AM
hi my 99 does the same thing. it has remanned inj earlier this year and all glow plugs work as designed. the smoke goes away if left idling in a few minutes or 3/4 of mile after driving off. since my coolant never changes need adding to, i assume mine is either poor compression ( mine had one of those "performance" cones when i bought it) or an injector that isn't right. i will do a cyl contribution test today. i recommend you do the same if you have access to auto enginuity or other scanner.
lght1 is offline
