Anyone figure out a high idle switch for the 7.3 yet? - Ford Powerstroke Diesel Forum
post #1 of 35 Old 09-20-2013, 10:35 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Update::: Write up here Write up: DIY 7.3 high idle
Looking to mod both my trucks to high idle this coming winter but i dont want to have to buy the AIC or a chip. If no one has anyone have the wire diagrams for it i may be able to figure it out from that
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 35 Old 09-20-2013, 10:52 AM
Powerstroke Junkie
NCHornet's Avatar
Is there a reason why you don't want the AIC unit? I have seen them dirt cheap on Ebay, my buddy got his for $45 and it looked to be new. I highly recommend it if you live where it gets really cold.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 35 Old 09-20-2013, 10:55 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Because 1. i dont want that big unruly box on my dash, and 2. Why spend even $45 for one when i could just buy a max $5 switch and some wire and just flip it and go
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 35 Old 09-20-2013, 03:22 PM
JSchuricht's Avatar
If you have a chip, most tuners offer a high idle setting. Otherwise the throttle is electric, pull it off and check the range with a OHM meter. Buy a POT that matches that range and wire it in with a switch. Flip the switch and turn the pot till you get the RPM you want. It wouldn't hold RPM with a varying load but would give you basic functionality.
JSchuricht is offline
post #5 of 35 Old 09-20-2013, 07:49 PM
kclough's Avatar
My 02 had high idle stock
kclough is offline
post #6 of 35 Old 10-30-2013, 09:55 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Bump anyone have the wire diagrams for the pedal sensors?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 35 Old 10-30-2013, 10:04 AM
Greenman01 is offline
post #8 of 35 Old 10-30-2013, 10:16 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Nice find bud, i knew there was no reason why this couldnt be done. I may simplify mine a bit more than that. Ill do a write up when i find the time to tackle this thanks
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 35 Old 10-30-2013, 10:23 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Subd.
2000-7.3L is offline
post #10 of 35 Old 11-10-2013, 05:52 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
I started tackling this today. I got her all all hooked up and flipped the switch and the rpms soared!!! i flipped it off before it got too far but i couldnt figure out why the hell it kept doing that so i gave up and went inside to do some more research.
Something i think is worth mentioning is looks like i was thinking backwards with the pot. I thought ohms go up, rpms go up. Thats wrong, its ohms go down rpms go up. So im gonna shoot out there tonight real quick(after walking dead of course) and try it the other way around and see how it works and then ill report back.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
