Throwin some Codes - Fuel Pump Secondary Circuit High?? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-20-2013, 06:53 AM Thread Starter
Hey guys, Truck is running a little rough. I am really hoping this is a quick easy and cheap fix. Edge Evo gave me the following codes.
P0232 - Fuel Pump Secondary Circuit High
P0236
Any help with this would be much appreciated.
Not to worried about these...
P0541
P0640
I know these have to do with the AIH. I did that 6637 do it yourself sorta thing and just have the sensor tied up.
shanerbanner10 is offline
post #2 of 14 Old 09-20-2013, 03:51 PM Thread Starter
Anybody got anything?
post #3 of 14 Old 09-20-2013, 05:36 PM
tommygun's Avatar
codes
po236 turbo boost sensor a circuit performance
2002 7.3 6637 edge evo2 4inch lift 35 tires no muffler
tommygun is offline
post #4 of 14 Old 09-20-2013, 05:37 PM Thread Starter
How to get rid of these?
post #5 of 14 Old 09-20-2013, 05:49 PM
tommygun's Avatar
codes
looked it up and says map senser overboost throws this code
tommygun is offline
post #6 of 14 Old 09-20-2013, 05:50 PM Thread Starter
Overboost? Hmmm so nothing really to worry about.
I'm more worried about this fuel pump stuff. Saw something on another forum that said not to drive it around with this code.
post #7 of 14 Old 09-20-2013, 05:54 PM
tommygun's Avatar
codes
OBD-Codes.com
Your OBD-II Trouble Codes Repair Site
HomeSTORE
Trouble Codes
Forums
FAQsSearch
URL of this page: P0232 Fuel Pump Secondary (Feedback) Circuit High Voltage
Share on facebookShare on twitterShare on emailShare on printMore Sharing Services42P0232 High Voltage Fuel Pump Secondary Circuit
OBD-II Trouble Code Technical DescriptionFuel Pump Secondary (Feedback) Circuit High Voltage
What does that mean?The fuel pump is powered by the fuel pump relay. When the PCM (powertrain control module) activates the fuel pump relay, voltage is supplied to the fuel pump and it pressurizes the fuel system. Some vehicles have a feedback on the fuel pump supply circuit. This is simply a circuit spliced into the voltage feed to the fuel pump. The splice is usually located close to the PCM.
The PCM monitors this feedback circuit to ensure that there is proper voltage being sent to the fuel pump. As it activates the fuel pump relay, it expects to see battery voltage on the feedback circuit. If the PCM sees an unexpected high voltage when the fuel pump isn't activated, P0232 may set.
SymptomsSymptoms of a P0232 DTC may include:
MIL (malfunction indicator lamp) illumination
Fuel pump runs with key off
Small amount of voltage present on FP (fuel pump) voltage supply circuit due to short
CausesPotential causes of a P0232 code include:
Bad FP relay
Short to voltage on FP voltage supply circuit or feedback circuit
Short to ground on PCM
FP relay control circuit PCM
FP relay control driver shorted to ground internally
Possible SolutionsIt is possible with a P0232 for the fuel pump to be running continuously, even with the ignition off. If that's the case and you can hear the fuel pump running, you may be able to disregard some of the following checks. Turn the KOEO (key on engine off) and wait for a few seconds. This allows the PCM to complete it's fuel pump pre-cycle. Now, using your scan tool (if you have one) observe the FP VOLTAGE FEEDBACK reading in the datastream. This reading indicates what kind of voltage the fuel pump is receiving.
If you don't have access to a scan tool, use a voltmeter to read the FP voltage at the fuel tank. If your reading shows any voltage at all present to the fuel pump with KOEO (or if you can hear the pump running), remove the FP relay. If the voltage remains, or the fuel pump continues to run, then there is a short to voltage on the FP voltage supply circuit or on the feedback circuit. Repair as necessary. If the voltage disappears (or the pump quits running) with the FP relay removed then try replacing the relay with a spare one. Upon reinstalling the spare relay, if the voltage disappears, the relay was faulty due to a short. If, though, after replacing the relay voltage is still present, suspect that the PCM FP relay control circuit is shorted to ground.
Check for a short to ground on the PCM FP relay control (ground driver) circuit by removing the FP relay and ohm between a good ground and the PCM FP relay control. There should be no continuity to ground with KOEO (after the FP pre-cycle is completed). If there is continuity to ground the wire is shorted. Find the short to ground and repair as necessary. If you can find no physical short, It may be necessary to snip the FP relay control wire close to the PCM connector where it will be easy to repair and check for continuity to ground with KOEO coming OUT of the PCM. If there is no continuity the wire is shorted in the harness. But if continuity exists, the driver may be internally shorted to ground and the PCM may require replacement.
Article written by Dale Toalston
Related P0232 Forum TopicsThere are currently no related topics in our car repair forums. Post a P0232 forum topic in our auto repair forum now.
Go to the auto repair forum now to ask your question!
Need more help?If you still need help regarding the P0232 trouble code, please post your question in our auto repair forums.
NOTE: This information is presented for information purposes only. It is not intended as repair advice and we are not responsible for any actions you take on any vehicle. All information on this site is copyright protected. If you want to share this article or information with others, please link to this page, don't copy and paste it elsewhere.
Actron CP9125 PocketScan Code Reader
Tell-a-friend - About Us - Contact Us - Links
Note: All information on this site is copyright 2004-2013 OBD-Codes.com
The information contained on this site is presented as information only. We are not responsible for any actions you take on your vehicle. If you have any doubt as to repairs on your vehicle, please contact a qualified technician.
Ask a Mechanic Online NowAsk a Mechanic Online NowA Mechanic will answer you in minutes.
Ask a question. Get an answer ASAP.A Mechanic will answer you in minutes.
Ask a question. Get an answer ASAP.Type your question here...Type your question here...Type your question here...
Optional:
Select Car MakeSelect Car MakeGeneral / Don't KnowAcuraAudiBMWBuickCadillacChevroletChryslerDodg eFordGMCHondaJaguarJeepLexusMercedesMercuryMotorcy clesNissanPontiacRVsSaturnToyotaVolvoVolkswagenOth erAdChoices
tommygun is offline
post #8 of 14 Old 09-20-2013, 06:01 PM Thread Starter
Thanks for the help.
Do you think I'd be ok driving with this code for the next week or so?
post #9 of 14 Old 09-20-2013, 06:07 PM
should of bought a 7.3
sean andreano is offline
post #10 of 14 Old 09-20-2013, 06:08 PM Thread Starter
It is a 7.3 hence why this is posted in the 99-03 7.3L section of the forum.
