Boost numbers? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-19-2013, 06:40 PM Thread Starter
Wyofordpower's Avatar
Quoted: 2 Post(s)
Boost numbers?
I was wondering what kind of boost numbers guys are seeing with stock turbo, no chip and 4 inch exhaust. I have never seen mine hit more than 17psi at wot. I just put in bellowed up pipes to replace leaky stockers and there was no change in top boost numbers.
Could I need to adjust the wastegate somehow?
For more info, it does seem to build boost faster with the new up pipes.
Any info is appreciated
Wyofordpower is offline
post #2 of 9 Old 09-19-2013, 07:09 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 20 Post(s)
You're okay. I'm completely stock. No turbo mods, tunes, anything. Just a 6637 and straight piped to a 4" Y-pipe dumped in front of the tire. I can only get 18 on a good day.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 9 Old 09-19-2013, 07:54 PM Thread Starter
Quoted: 2 Post(s)
Okay that sounds better. My buddy with an early 99 hits 23psi with just an exhaust and hypertech programmer. Course I just remembered that the early 99's have a different turbo. But he said that he adjusted the wastegate to get from around 20 to 23.
I'm not worried about the number as long as the truck runs good. And with no smoke and 17mpg highway I'm pretty satisfied. But hey if there is a free way to make it better why not?
Thanks for the reply.
post #4 of 9 Old 09-19-2013, 11:24 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
17-18 is about as high as you can get with a truck running the stock tuning.
with a good chip and billet compressor wheel, you can see in the 30's.
and tightening down the stock wastegate can help, the stock wastegate isnt very good.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #5 of 9 Old 09-19-2013, 11:27 PM
i hit 24psi with mine, reading off my torque app. This was pulling a 10,000lb 28' enclosed car trailer loaded down. I was pulling up a hill and it kicked down out of OD @ 70mph. I do have my wastegate unhooked.
on a empty WOT run i get around 18-19psi.
2002 F350 CC Auto 2x4 SRW SB
jhobbs26 is offline
post #6 of 9 Old 09-20-2013, 10:01 AM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
17psi is normal for a bone stock setup. With the wastegate unhooked you can see around 24. Add a chip/programmer to that and you can see 30+.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 9 Old 09-20-2013, 03:17 PM
My truck with wastegate unhooked, big a/f, 4 inch exhaust, AIH delete, gen 1 WW and ported intake manifold I hit 26.
chucktor is offline
post #8 of 9 Old 09-21-2013, 04:19 PM Thread Starter
Quoted: 2 Post(s)
Are there any problems associated with unhooking the wastegate?
post #9 of 9 Old 09-22-2013, 10:42 AM
Quoted: 289 Post(s)
not at the boost levels we see. you will be fine
