Roof running lights - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-19-2013, 10:35 AM Thread Starter
Lilsinkko's Avatar
Roof running lights
I have a 01 F350 4 door long bed it has everything on it but roof running lights and I want to put some on but idk how labor intensive it is if you could let me know that would be great.
Lilsinkko is offline
post #2 of 6 Old 09-19-2013, 10:47 AM
Raul@Stealth Automotive's Avatar
ill have to find the writeup but its not super hard but you will have to drill holes on your roof
Raul@Stealth Automotive is offline
post #3 of 6 Old 09-19-2013, 10:48 AM
here you go F250 Factory Clearance Light install
post #4 of 6 Old 09-19-2013, 07:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Super easy I just did mine I did a bit different.
That write up is perfect I was going to write one myself but I wouldn't have done any better.
If you want to do 7 lights like I did its easy.... get 7 lights lol and then cut the last 2 plugs and wire off the donor truck. Then splice in the extra two plugs to the end of the harness, leaving space.
For measurments I did very slightly different. I did 5" from the windshield instead of 5.5". Then if you want to do 5 use the spacing measurements that the write up has. If you want to do 7 like I did space the lights out 7" on centre from each one. Set all the lights on first to make sure you like what you see..
I like the Idea of 7 because that is something you can't do if your truck already has 5... I like to be different.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 6 Old 09-30-2013, 05:48 AM Thread Starter
Lilsinkko's Avatar
Thank you for the help
post #6 of 6 Old 09-30-2013, 06:39 AM
check out atomic LED.
2003 F250 7.3 CC SB FX4
TS Chip Tuned by Tony Wildman
4" MBRP Turbo Back Straight Pipe
Driven Diesel Regulated Return
International Bellowed Up-pipes
K&N Intake W/ 6637
Transgo Shift Kit
ATS Ported Turbo Housing
Wicked Wheel 2
EBPV Delete Pedestal-High Flow Outlet
3 Gauge Pillar Pod
Viper Remote Start w/Turbo Timer
potbss is offline
