debating on a leveling kit
is anyone running 35x13.5's with a leveling kit??? and what company would you recommend for a leveling kit also i found these things on ebay they are a 5 inch lift they replace where the leafs bolt to the bracket on the frame anyone using them??? are they any good?
I dont know if you can fit a 35 or not but by the looks of your truck it looks like your truck would look alot better with a leveling kit. Mine is in desperate need of one and I have one on the way. I bought mine from ebay.
What color is that? Dark ford blue? Does it look like mine? I'm asking because I need to repaint mine. Thanks, Luke |
im not sure on the color you could go to your local parts store that sells paint and they could probably look it up for ya there so they could match the paint i know my local parts store here could do it but it might be the dark ford blue because i got my trans am painted a dark blue metallic and its almost identical to my truck
im running 35s with a 5.5" fabtech lift and under hard abuse they will rub but not enough to hurt anything or enough that i cant do something i wanted to do.
well those 5 inch shackes i saw on ebay the other day are gone now i was thinking about getting them too
Okay I talked to my girlfriends father in law...he has a crew cab 350 longbed with 2.5 inch leveling shackles he said the tires he has on now are 35x12.5 pro comps....i can speak from experience that it looks badass, it makes the truck look like a tank going down the road....it almost looks like he has a 3 or 4 inch lift. He said his bumper was shimmed because he would rather do that than trim it a little.
I have the fabtech leveling kit and add a leaf in the rear with 35x12.5x16.5 bfg. No rubbing. Depends on the wheel you get. Get aftermarket wheels and you shouldnt have a problem.
Sticking to a 12.5" wide tire will clear better than the 13.5"..with a 2.5" kit..every bit helps. Watch the wheel offset.
Cary |
Jeong is that you?
so what is your offset then?
