Mileage expectation on tuned 7.3?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-18-2013, 11:20 PM Thread Starter
I am going to see a 2000 7.3 DRW tomorrow with 250k miles. My purpose for this truck is highway towing - mainly to tow a car hauler with cars I've bought at out of state auctions. I've had several 6.0s in the past and experienced decent mileage - 15-18 mpg unloaded and 10 mpg with a loaded 3 car hauler. What kind of mileage should I expect from a 7.3 motor with "tuning" software installed? Thanks!
stonework is offline
post #2 of 8 Old 09-19-2013, 01:01 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Hard so give you a real number on either of those... Way to many variables. I will tell you if the motor is taken care of and isn't ran with excessive EGTs it will last for a very long time! I worked with a guy that had almost 600k on his 96 F350 and he tows cattle/farm cr@p every weekend. Maintenance is an important factor, especially them fuel filters.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 09-19-2013, 02:55 AM
schlutzer's Avatar
Quoted: 18 Post(s)
As I understand it you should see similar MPG out of the 7.3... possibly even a little better loaded. if all stock.
If you want to do a little extra to the truck.
Pick up a good tuner, I recommend DP, and you'll do alright. I've also seen a test where putting all synthetic fluids in the drive train actually made a noticeable MPG difference.
Let the motor breath, 6637 are filter and turbo back exhaust will also give you a bit of a mpg boost. Single shot injectors are supposed to be good for 1-2 mpg as well.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 8 Old 09-19-2013, 04:31 PM Thread Starter
Thanks. I saw the truck this afternoon. Very smooth engine. No oil or even film on the bottom of engine and trans. Interior was rougher than I wanted. Only mechanical concern was the air filter housing only had one clip. The air filter was filthy and looked horrible when I lifted the side of the box and peeked in. I will continue to look and take my time.
post #5 of 8 Old 09-19-2013, 06:19 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Take a look at the turbo right away... pull the intake off and look... that broken air box is a big cause of a dusted turbo you need to check the fins for signs of dirt ingestion.
post #6 of 8 Old 09-19-2013, 06:34 PM Thread Starter
Thanks. That is what concerned me about the air filter box - turbo concerns. With the interior also needing seats, I passed. If the previous owner did not maintain the air filter, I can only imagine how neglected the fuel filter might be.
post #7 of 8 Old 09-19-2013, 06:41 PM
schlutzer's Avatar
Quoted: 18 Post(s)
oh I read that wrong sorry I thought you meant you had already bought the truck.
post #8 of 8 Old 09-21-2013, 12:00 PM
hansel's Avatar
Quoted: 100 Post(s)
With my PHP tunes using the 65hp tow tune I'm getting 11.2mpg towing a Keystone Laredo that weigh's in at just over 8,000lbs. I held a cruising speed around 70mph, a 7.3L stock will not have the power as the 6.0L so don't be looking for a 7.3L too blow down the highway unless you tune it.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
