Chip question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-17-2013, 03:33 PM Thread Starter
Chip question
If the previous owner of my 7.3 put a chip on it like an superchip and left it in a tune that way and I didn't know about it what would happen if I put a edge chip on it and went to tune it. Would the factory setting the chip downloads be the one programmed with the superchip tune? Then what would happen when I go to put it on 100 horse and has a previous tune?
Reason I ask is been having issues with my truck and wondering if that could be an issue? Or would it really make it run like chit if that happend.
redsmoke is offline
post #2 of 5 Old 09-18-2013, 05:05 AM Thread Starter
Somebody has had to have had this happen to them? I just want to know if it would even run if was programmed with one chip then re programmed with another chip.
redsmoke is offline
post #3 of 5 Old 09-18-2013, 08:35 AM
Powerstroke Junkie
NCHornet's Avatar
Some chips are stackable and some aren't, if they aren't the new one usually won't load. Some will load and won't run, all sorts of possibilities and I can't remember all the different possibilities, best is to call the tuners and ask them. If you don't have the original programmer the PO used then you will need to have your PCM reflashed with the correct tune, or buy/ find used, another PCM to put in.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 5 Old 09-18-2013, 05:42 PM Thread Starter
Thats what I was thinking. I do not want to stack chips at all just trying to get this truck to run back to normal. I been working on a miss for a year and its been to ford for them to tell me replace this or that after its already been done. How ever I am going to switch ford shops and see what next place tells me and see if they will dig deeper and probably have them reflash it.
redsmoke is offline
post #5 of 5 Old 09-19-2013, 11:29 PM
Quoted: 780 Post(s)
The 7.3 PCM's are not stackable. Dealer can reflash your pcm for well under $100.
Corey@CNCFAB is offline
