oil pan - Ford Powerstroke Diesel Forum
Old 06-13-2008, 03:21 AM
Got Whistle?
Feedback Score: 5 reviews
oil pan
Isn't there a TSB on our drain pans?
Mine's not looking so hot under there. Just curious what any of you have used for a coating on yours?
Old 06-13-2008, 11:51 AM
Yea mine looks like its got some rust spots on it too. I gotta hit it with a wire brush and some paint
Old 06-13-2008, 06:31 PM
Here's what you're looking for
05-20-3 Oil Pan Corrosion - 7.3l Or 6.0l - The Diesel Garage Forums
I on the other hand will be using this stuff and doing the pan on the next oil change.
Stop Rust - Outperforms POR-15 - Gas Tank Sealer - KBS Coatings - RustSeal in Colors
There sampler kit will be all you need to do the pan, for 17bucks
KBS System Sampler - Stop Rust - KBS Coatings - RustSeal
Old 06-13-2008, 07:52 PM
Awesome link to that sample kit! I am going to order 2 of them when I get my pay check!
Old 06-14-2008, 10:18 AM
Got Whistle?
Hey great info man, I knew I had seen that TSB somewhere...
I may use that stuff on mine too or the PM-13-A. I don't know yet...
Thanks again
Old 06-15-2008, 01:40 PM
International Threat
Wire brush and POR 15
Old 06-15-2008, 08:05 PM
Honestly I can say for sure cause I haven't used the POR15 but I've heard it can flake and you absolutly have to get to bear metal for it to work right when you prep the pan.
I've gonna give the KBS a try, I saw a wright up on PSN for someone who did it and it was not only a paint barrier but it was a solid thick hardened coating when it was all done. I've just heard this stuff works better than POR 15, but again I'm not the expert because I haven't used either.
