borg warner cps - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-15-2013, 08:28 PM Thread Starter
blue99stroker's Avatar
Quoted: 249 Post(s)
borg warner cps
so i tried the international cps part #1876736C91 for about a month.
i was using the ford recall cps previously
idle was improved, gained about a mpg, took longer to start than with the ford recall cps, and power seemed down.
just switched to the borg warner cps from oreily's and i am stoked.
the international cps will be my extra extra extra cps now. starting a collection.
i know they have had issues with trucks stalling when you use your windshield wipers, so i have tested it multiple times and havent had an issue.
now for the good stuff, starts better, power is up, throttle is much more responsive and the truck idles great!
have yet to run a full tank so ill post back on results.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #2 of 11 Old 09-15-2013, 09:00 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
How much was that bad boy?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 09-15-2013, 10:22 PM
payne5757's Avatar
Just went through a similar experience every I tried the Standard Motor Products brand CPS which is still a clone of the original large magnet black CPS. So far I'm impressed with the same results as you.
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
post #4 of 11 Old 09-16-2013, 06:35 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Wait a min... Just because the BW CPS is made with Black plastic, that doesn't mean it's anything like the original Ford Black CPS (with it's, occasional, wipermotor conflict)
NoRalPh is offline
post #5 of 11 Old 09-16-2013, 06:46 AM
goats's Avatar
Quoted: 2 Post(s)
Try a contribution test and see if it fails. #8
goats is offline
post #6 of 11 Old 09-16-2013, 11:35 AM Thread Starter
Quoted: 249 Post(s)
yes its black. it could be pink for all i care
just because it looks the same does not mean it is the same.
well seeing as the #8 fails a cct whether not im using the ford recall cps, the IH cps,and possibly the bw cps i dont see how it would matter.
oh and i paid 33 bucks from oreily's.
post #7 of 11 Old 09-16-2013, 11:47 AM
payne5757's Avatar
If its a replica of the old black CPS, it actually has a larger stronger magnet that reads better without having to shim it just right like the newer ones have problems with.
post #8 of 11 Old 09-16-2013, 11:48 AM
Quoted: 143 Post(s)
Yea, that's what I saying because of your reference to wiper problems that you apparently associated with Black Plastic
NoRalPh is offline
post #9 of 11 Old 09-16-2013, 02:34 PM Thread Starter
Quoted: 249 Post(s)
oh i just meant id read about the bw cps having wiper issues. the color which is irrelevant. i didnt know it was black until i bought it the other day. so color wasnt a seller.
i have washed the truck with the wipers on full blast and it never had a hiccup.
just thought id let everyone know MY good luck. everyone might not have the same results but i am happy with the outcome.
post #10 of 11 Old 09-16-2013, 04:28 PM
Quoted: 143 Post(s)
The BW had wiper interference too? I never heard that.....
Even the Ford CPS from 20yrs ago wasn't all that prone to it (I still have the original one in my '02 and never had a problem). It must have been an issue with a certain motor or it degraded in a certain way, something like that
NoRalPh is offline
