Truck eating Neutral safety switches - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-15-2013, 10:47 AM Thread Starter
99 SD CC 4x4 auto. I had another thread trying to figure out why it wouldn't start. Traced it to the switch. Installed last night. Worked fine. This morning same ol' BS. Nothing. So what could be eating the switch??
markwemple is offline
post #2 of 10 Old 09-15-2013, 11:42 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
What makes you think it's being "eaten" instead of just out-of-alignment?
NoRalPh is offline
post #3 of 10 Old 09-15-2013, 11:46 AM
Quoted: 759 Post(s)
Bad ground or chafed wires shorting it out???
Corey@CNCFAB is offline
post #4 of 10 Old 09-15-2013, 12:11 PM Thread Starter
Last night it was working and completely installed. My concern is that there is a harness problem and with the issues described where would you look?
post #5 of 10 Old 09-15-2013, 04:38 PM
Quoted: 17 Post(s)
You sure you have the bolt tight on the linkage under the dash? That will cause the same issue
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #6 of 10 Old 09-15-2013, 04:57 PM Thread Starter
Anyone have a pic of the bolt?
post #7 of 10 Old 09-15-2013, 05:44 PM
Quoted: 17 Post(s)
It's a torq (sp)bolt & very easy to find. You have to pull your lower dash panel by the brake & accelerator pedal, held by a few plastic Phillips screws. That's if it's still there. Look by the steering shaft & you will see the linkage with the bolt or bolts( can't remember if it was one or two). Sorry I didn't take a pic when I did mine a few months ago.
TBJK is offline
post #8 of 10 Old 09-17-2013, 05:40 AM Thread Starter
So, with the help of a pic, I was able to find the 2 screws that secure the shifter assembly. 1 was a turn loose. Now things seem OK. A combo of the shifter and switch. Chicken egg...?
post #9 of 10 Old 09-17-2013, 11:14 AM Thread Starter
DID IT AGAIN!
post #10 of 10 Old 09-18-2013, 08:08 AM Thread Starter
Well, the first 2 tries, I had to use a screwdriver the rest of the day I could use the key. WTF?
