Need tire opinions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-15-2013, 08:50 AM Thread Starter
Need tire opinions
I was planning on installing a 2.5 inch leveling kit on my 2000 f250 cc 4x4. I've been putting it off and I need to go ahead and replace my tires first. I'm currently running a 285 and they look good with the stock height. I'd like continue to run my Lariat rims and I was wondering what's my best option for size. Should I stay with a 285 even with the level or can I run a 315 without a lot of issues? If I can run the 315 I'll go ahead and knock the lift and tires out together.
M3xpress is offline
post #2 of 9 Old 09-15-2013, 09:22 AM
Powerstroke Junkie
NCHornet's Avatar
I believe with a true "leveling kit" you can squeeze 35" under there. Just make sure you use a kit with a relocatable trac bar or an adjustable trac bar, if not both. For lifts and leveling kits I highly recommend Cary at CTPerformance, he will set you up with the right items.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 9 Old 09-15-2013, 09:42 AM
Quoted: 902 Post(s)
Feedback Score: 3 reviews
You can run 35"s no problem with X code springs. For $400 or so you can get them, adj track bar, new u bolts. Those leafs will raise your truck to a level looking height without adding extra crap in there. Putting blocks with longer u-bolts increases axle wrap.
Corey@CNCFAB is offline
post #4 of 9 Old 09-16-2013, 08:58 AM Thread Starter
So the 315 is good with the level but how about with the Lariat wheels? Am I maxed out with the 285 on that rim?
M3xpress is offline
post #5 of 9 Old 09-16-2013, 02:57 PM
cowens726's Avatar
I'm in the same boat as you except my tires are still good, (285s) I leveled my truck and it looks decent with them but 315s would be better. I was told by a buddy of mine that runs a tire shop that they will be fine on the stock wheels though not ideal. No safety concerns at all from what he told me so when it's time for new skins I'll be going to 315s. Hope this helps.
cowens726 is offline
post #6 of 9 Old 09-16-2013, 06:56 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I feel that 315s are too wide for stock rims, however there are many guys who run them.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #7 of 9 Old 09-16-2013, 07:05 PM
Macon's Avatar
I'm on 285/75R17, with some sort of leveling kit. It's the perfect size to put front and rear fender wells the exact same height off the ground. I hate the look personally and plan on 350 blocks for the rear.
This is them, though it's on '05 wheels.
[IMG][/IMG]
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #8 of 9 Old 09-17-2013, 02:54 PM
Quoted: 31 Post(s)
Depending on how wide your tires are a 35 may be too big. i run a 35x12.5 and on stock 2000 lariat wheels they rubbed the leaves at full turn.
If you go to les schwab they will put as many tires on the rim as you want to test how they fit. Find one you like then order it.
If you do a lot of highway driving and like good gas mileage, you would be fine with a 35x10.5. the 2" wider tire netted me about 1 MPG loss.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #9 of 9 Old 09-17-2013, 07:22 PM
I can tell you from my experience that 315s are not gonna be ideal for stock wheels. I have a 2" pro comp leveling kit with 295/75/16s on stock wheels and they are too wide for the wheel. I have to run them at 45-50 psi to get a flat footprint and they should be run at 65-70. They are e-rated. They are the Toyo open country at2 and I love the tires. I am gonna be getting some 16x10 wheels as soon as money allows. My truck is pictured in sig.
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
