Stock Fuel System Discussion - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-14-2013, 09:51 AM Thread Starter
01f25073's Avatar
The stock fuel system is pretty basic but I have a question about it. Both of the fuel rails are "dead-headed" as there is an entry of fuel but no return. Because of this, many of our trucks have a different injector, #8, to help it get fuel. The #6 injector supposedly "robs" #8 from getting fuel causing cackle. The even injectors are on the driver's side which the fuel is fed from the front of the rail at injector #2.
If this is true then the passenger side should have the same problem but all of the odd injectors are the same. The fuel is fed from the back, opposite of the evens, in injector #7 to injector #1. Why doesn't injector #1 need to be different if injector #8 does? (being that these injectors are both the farthest from the fuel feed)
Anyone know the answer?
2001 F-250 4X4 CC SB 7.3, 4R100 3.73, BFGoodrich All-Terrain TA, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar headlamps and 5000K LED lamp replacement interior, clear headlight assembly, Moog greaseable u-joints, Moog greaseable ball-joints, Moog front hub assemblies, retractable hitch in bed, original black CPS (BEST "mod" to have), Energy Suspension bushings, Red ELC, Edge Evolution, Walker BTM, Donaldson AIS
01f25073 is offline
post #2 of 6 Old 09-14-2013, 11:12 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
It has to do with the Firing Order (1-2-7-3-4-5-6-8) Because 6 & 8 are sequential and located right-next to one another...
NoRalPh is offline
post #3 of 6 Old 09-15-2013, 09:18 AM
Powerstroke Junkie
NCHornet's Avatar
If you don't want to spend the money for a RR system you can install a crossover line that will help balance out the fuel pressure load. Some say it makes a world of difference and others none, but common sense tells you it must help, even if just a little. I have had mine in the box it came in for over a year now, I really need to slap that thing on before Winter gets here.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 6 Old 09-16-2013, 11:46 AM Thread Starter
01f25073's Avatar
NC, I replaced my HPOP (among a lot of other things) this past week and the HPOP I bought did not have the check valve springs in the hose fittings. Because of this, the instructions stated to remove any HPOP crossover line as the removal of the check valves accomplished the same thing. If this is true, then why couldn't you remove the check valves going into the fuel rails to also accomplish the same thing?
01f25073 is offline
post #5 of 6 Old 09-16-2013, 03:35 PM
Quoted: 157 Post(s)
That just can't be true....
They are two completely different functions.
NoRalPh is offline
post #6 of 6 Old 09-17-2013, 04:33 AM
timmyboy76's Avatar
I want to say, they 9cv's) have something to do with the split shot injectors...so the pulse doesnt backfeed into the bowl or something to that nature.
For what its worth, i removed mine.(cv's)..didnt notice anything outta the norm.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
