Help w/ replacing hpop lines n orings? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-13-2013, 04:50 PM Thread Starter
Eco Taxi's Avatar
As the title states I'm replacing my hpop lines that go from the hpop to each head.
One of my lines is leaking so might as well replace both.
My question is that through my reading I know I can simply replace the line but it looks like there is also a hpop discharge fitting at each end? Additionally a spring behind the fitting at the hpop. Then also o rings.
I've been on dieselorings.com and have been overwhelmed on what exactly I need.
Should I simply replace the lines or also pull all the fittings and replace the orings? If so what do I need?
I've looked at these items
DieselOrings: High Pressure Oil Pump reseal kit - 7.3L Powerstroke
HPOP Discharge Hose fittings
DieselOrings: HPOP Cylinder Head Quick Disconnect Hose Fitting Repair Kit 1999 - 2003 7.3L
HPOP Quick Disconnect Hose Fitting Repair Kit 1999 - 2003
High Pressure Oil Pump Discharge Hose Fitting - High Flow 1999-2003
HPOP Hose fitting Hose fitting at the engine oil rail connection F81Z 9N332 AA
Any help is appreciated, outside of what's above I know I at least need the hpop hose for each side and the quick release tool
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #2 of 4 Old 09-14-2013, 06:28 AM
timmyboy76's Avatar
while your in thee, might as well replace ALL the orings. Comes with what.where location for each....
Riffraff Diesel: "Mechanics Parts Cabinet" Combo kit
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 09-14-2013, 09:13 AM
Powerstroke Junkie
NCHornet's Avatar
As already said replace them all, at least the HPO lines since this is a common place for leaks, as you found out. You can buy a premade tool or make your own, flip a coin, they both work.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 4 Old 09-14-2013, 08:23 PM Thread Starter
Eco Taxi's Avatar
Thanks for the link
Kyle
Eco Taxi is offline
