Scratching my head on chip - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-13-2013, 05:43 PM Thread Starter
Unhappy Scratching my head on chip
2002 7.3... I had a super chip for a little bit then I upgraded to a DP set up... With super chip I ran a 15.8, with the DP I can't get it below 16.2.... No boost leaks I'm pushing 27psi... All vitals good.. Any input would be appreciated.. I'm kinda disappointed to tell you the truth
fl-diesel is offline
post #2 of 9 Old 09-13-2013, 11:27 PM
Quoted: 759 Post(s)
Contact Justin@DP-Tuner on here.
Corey@CNCFAB is offline
post #3 of 9 Old 09-13-2013, 11:29 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
That's a first for me, canned tuners run faster than custom ones!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 9 Old 09-14-2013, 05:21 AM
schlutzer's Avatar
Quoted: 18 Post(s)
DP with what tune? if you're truck is all stock you may actually make less power on the 120 or 140 tunes. I tested it when I was auto, consistently almost a full second slower than with 80. I'm an E99 with a somewhat weak HPOP
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 9 Old 09-14-2013, 07:17 AM Thread Starter
ran down the track with 80,120,and 140.... 15psi boosted launch
post #6 of 9 Old 09-14-2013, 10:19 AM
Powerstroke Junkie
NCHornet's Avatar
could be all sorts of things, before blaming Jody and the folks at DP start with the simple things like tire pressure. You wouldn't believe how much tire pressure can affect drag times.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 9 Old 09-14-2013, 10:27 AM Thread Starter
im not blaming jody or the dp folks whatsoever... i emailed them for their input, probably get back to me on monday... tire pressures good... everythings good... only thing i cant monitor is fuel pressure or fuel rail pressure..
post #8 of 9 Old 09-16-2013, 04:54 PM
Justin@DP-Tuner's Avatar
Quoted: 50 Post(s)
Let me know when you are able to test fuel pressure as we talked about. We will help get this figured out for you.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #9 of 9 Old 09-16-2013, 08:54 PM
Joel's Avatar
Quoted: 10 Post(s)
Possible that the tranny is slipping a little with the added power?
A small amount of slip would be difficult to notice, but it would show up at the track.
What were the the mph of the two days?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
