Alternator bad? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-13-2013, 11:57 AM Thread Starter
panteramatt's Avatar
Quoted: 37 Post(s)
Alternator bad?
I have a 2000 psd and I noticed on longer hauls for about a year now my battery light would flash a few times. I replaced the alt about year 1/2 ago. So I went on a trip a week ago and when I stopped for fuel the batterys were dead and it wouldnt start. Batterys are good. SO I replaced the alt today with another new one and when I first started it it only read 11.98 volts for about 10 seconds then jumped to 14.38 and stayed there. Is there something else that could be wrong or was it cause I just replaced the alt?
panteramatt is offline
post #2 of 9 Old 09-13-2013, 12:53 PM
JSchuricht's Avatar
Those voltages are normal. When you first start the truck, the glow plugs will come on regardless of temperature and bring your voltage down. Once they shut off your voltage goes up and 14.38v is perfect.
I would check the 2 wire plug on top of the alternator. It may have a bad connection that is causing the alternator to turn off and the battery light to come on. I would also rig up a in cab voltage gauge so you can see if your voltage is dropping while driving, the stock one is nearly useless. Did you check the voltage when the truck wouldn't start? That would give you an indication if the alternator is bad, you have a huge draw like a glow plug relay stuck on or a bad cable.
JSchuricht is offline
post #3 of 9 Old 09-13-2013, 05:21 PM Thread Starter
Quoted: 37 Post(s)
Ok the makes sense. Is there anywhere in the cab I can hook a ohm meter up momentarily?
post #4 of 9 Old 09-13-2013, 06:12 PM
JSchuricht's Avatar
You could use the power port but you should set your meter to dc volt. OHM is to measure resistance.
post #5 of 9 Old 09-13-2013, 06:44 PM Thread Starter
Quoted: 37 Post(s)
Yea I just call it an ohm meter
post #6 of 9 Old 09-14-2013, 10:33 AM
Powerstroke Junkie
NCHornet's Avatar
If you bought it at Auto Zone, or other chain store, better get use to changing them out. Last time I delt with a alt from a chain auto parts store I ended up going through 6 in a year and a half period, not on this truck. They are rebuilt with the cheapest components they can find and they rely on the fact that most people trade vehicles every 2 years or less. If you want a quality alternator or starter buy it from DB Electric. They are all I recommend any more.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 9 Old 09-14-2013, 01:23 PM Thread Starter
Quoted: 37 Post(s)
Funny you say that as I got a remanufactured one from advance auto that failed. The new one is from db electric
post #8 of 9 Old 09-15-2013, 10:12 AM
Powerstroke Junkie
NCHornet's Avatar
Quite possibly the last one you will ever put in your truck. I want to try one of their high torque starters the next time I need one.
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #9 of 9 Old 09-15-2013, 11:51 AM
Quoted: 725 Post(s)
Either that one or DC Power Engineering.
Corey@CNCFAB is online now
