How to measure lift on my truck - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-12-2013, 08:51 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
When I bought my truck it was already lifted. I need to buy new shocks and I'm not sure how much lift it has. I've always been curious just how lifted it is- I think it's only 2", but it could be 4". What kind of measurements can I take? Shock eye to eye? Bottom of fender to ground?
Also considering the Bilstein 5100 series shocks. Any confirmations on those or other recommendations?
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 14 Old 09-13-2013, 08:07 AM
Powerstroke Junkie
NCHornet's Avatar
Numerous places that you can take measurements from, take your pick and compare that to a truck at stock height. Or post a photo, many of us can tell you just by looking at it.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 14 Old 09-13-2013, 09:23 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Center of hub to fender in front is 26.5". Center of hub to fender in rear is 26 3/4". Front shock eye to eye is 18 3/4". Block on rear axle is 3 1/2" (under leaf springs). Thanks!
post #4 of 14 Old 09-13-2013, 09:47 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Let me know if there are any other helpful measurements. The truck is parked on a slight incline in the photo with the front of the truck lower than the back. Tires are 285 75 16s and pretty new with BFG AT Lugs.
post #5 of 14 Old 09-13-2013, 11:56 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I just measured my neighbors stock f-250 for reference:
Front center of hub to fender is 24"
Rear center of hub to fender is 25-1/2" with the stock 2" f-250 blocks.
So it looks like your truck has a 2-1/2" or 3" lift on the front and is stock height in the rear with the f-350 blocks.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #6 of 14 Old 09-13-2013, 12:05 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Thanks! It is an F350, do they sit taller than a F250 with the extra suspension? So that means my truck just has a leveling kit, correct?
post #7 of 14 Old 09-13-2013, 01:21 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, f-350's have 3-1/2" blocks, and f-250's use blocks that are just under 2" tall.
The springs are the same on f-250's and f-350's, the difference in the rear height is due to the different size blocks.
GregsSD is offline
post #8 of 14 Old 09-13-2013, 01:27 PM
Raul@Stealth Automotive's Avatar
looks like its just a leveling kit.... if your looking for a good deal on some great shocks check these out: http://stealth-automotive.com/index....roduct_id=1859
Raul@Stealth Automotive is offline
post #9 of 14 Old 09-13-2013, 02:42 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I don't think I ever knew that! So that's the difference between a 3/4 ton and a 1 ton?!
post #10 of 14 Old 09-13-2013, 02:44 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Thanks, I'll give them a look. What is the advantage to the 5160 front shocks that you offer? So it looks like I can just order the "stock" length shocks and they will work?
