Well mark up another Tranny for the 7.3..what to do, what to do - Ford Powerstroke Diesel Forum
post #1 of 41 Old 09-12-2013, 04:07 PM Thread Starter
Well. It finally gave. My transmission went kapoot. Last week Friday. Would shift for ****. would wind up to 2500 in every gear then shift. Brought it to the highway. hit 3rd and bounced of rev limiter. Wouldn't shift no matter what I did. Well I left it for the weekend. Thought maybe the computer was freaking out or something. Brought it to the gym. Drove fine. Shifted where it was supposed to. On my way home I noticed a noise. Whining like. Couldn't hear much over my motor and exhaust.
Well pulled in my driveway. hit the gas. and nothing. through it in park. Put in back in drive. and probably 10 seconds later. kicked in.
Well, pretty sure my transmission has went. haha Its been a long haul at 220K on the stock tranny. and she went.
Is it gone? or should I look at alternatives before I dump money? haha
What I am asking now. Should I go with a rebuild? little beefier then stock, since im spinning 40 inch tires. Manual? Or just go with a built. My cousin said built. But my pockets aren't that deep. But I can make it work if I had to.
Just wanted to hear what other 7.3 owners have to say!
My truck Is mainly a weekend daily. I haul cars once in a while. Haul wood. Skid steers. But mostly that's pretty rare. id say maybe a dozen or so times a year. Otherwise she is my weekend warrior. Play toy.
2003 Ford F-350
7.3 Powerstroke!
8 inch BDS lift.
4 inch MBRP Exhaust
Intake
Edge Juiced w/ Attitude.
40 inch tires on 20 inch Black Moto Metals.
Preston16 is offline
post #2 of 41 Old 09-12-2013, 05:05 PM
Quoted: 902 Post(s)
Feedback Score: 3 reviews
You can go with a quality rebuild and install a BTS or John Wood valve body with a 6.0 oil cooler and be good for quite awhile.
But running 40's, if you plan on keeping the truck forever, if you can swing the money, get a BTS or John Wood transmission.
Corey@CNCFAB is offline
post #3 of 41 Old 09-12-2013, 06:55 PM
BTS gets my vote.
Sent from AutoGuide.com App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #4 of 41 Old 09-13-2013, 06:27 AM
rascal's Avatar
What gear's are you running for those 40's? Unless you are running 4.56's or lower you are going to keep eating transmissions.
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #5 of 41 Old 09-13-2013, 06:58 AM
Powerstroke Junkie
NCHornet's Avatar
40's sure ain't helping any trans issues. BTS is the Cadillac for bullet proof transmissions, it is what most of the pullers are using, but Cadillac's aren't cheap. Second choice would be John Woods, valvebody can be from either one, not much you can do to one that is "new and different". But if you haven't already you need to regear those diffs for those monster chunks of rubber that you are spinning.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 41 Old 09-13-2013, 07:24 AM
Quoted: 6 Post(s)
I'd go with a Ford 4R100HD. You can get them for just over $2k and they have a nice warranty serviceable at any Ford Dealer.
If/When mine goes, I'm getting the HD.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #7 of 41 Old 09-14-2013, 12:45 PM
RPM Tim's Avatar
...Check your fluid?
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #8 of 41 Old 09-14-2013, 01:26 PM
camsmell's Avatar
running that edge probably isn't helping the trans at all either
99.5 F250 full force stage II, riff raff frx hpx, T 500, 6637 mbrp stainless 4", DP Tuner, Isspro boost pyro trans, 4" lift john wood vb, 38r, coolant filter, ccv mod, cooling mist stage I, non ebpv pedestal
camsmell is offline
post #9 of 41 Old 09-14-2013, 01:36 PM
Diesel Addict's Avatar
Swap in zf-6 and a dual disk clutch and be done with the whole problematic auto once and for all!
2006 F-350 CCLB
6-Speed Manual
6" Fabtech Lift, looking to go a few inches shorter and higher quality
35" Toyo Open Country MT's
AFE stage 2
MBRP 4" turbo back straight pipe
SCT Livewire tunes by Eric
Studded and deleted
The right to keep and bear arms SHALL NOT BE INFRINGED!
Diesel Addict is offline
post #10 of 41 Old 09-15-2013, 09:10 AM
Powerstroke Junkie
NCHornet's Avatar
The HD is simple marketing at it's best. If you saw the difference in the internals of what Ford uses and what BTS uses you would laugh at their HD trans. Will it work for 90% of PSD owners? Probably. Unlike other shops that don't want customers in the "work area" Brian, welcomes it. He shows you the cast parts that Ford and every other rebuild kit uses and then he shows you the billet made components that he has custom made that is what he installs in one of his transmission jobs. Of course quality like this comes with a price, many cannot, or will not, afford it. I hope that when mine goes that I can some how afford one, lol!!!!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
