coolant test strips - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-12-2013, 03:04 PM Thread Starter
adavis11's Avatar
coolant test strips
I have an early 99 7.3 with the green coolant in it. I need to know what test strips to use to check the sca levels. Which ones work best and are easily available. And how often do I need to test my coolant?
2013 6.7 Powerstroke Platinum
adavis11 is offline
post #2 of 8 Old 09-13-2013, 04:48 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
I have used Cummins and Napa's coolant test strips... both seem to work fine. The OEM recommendation is every 15k or once a year IIRC.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 8 Old 09-13-2013, 07:04 AM
Powerstroke Junkie
NCHornet's Avatar
In the old days before ELC's I used Fleetrite strips from IH and checked it every 6 months and add the additive as needed, don't use those pre-charged coolant filters to regulate SCA's. These test strips have a very short shelf life so don't buy the 50 pack, and be sure to inspect the date before paying for them. But to be honest with you, why not switch over to a ELC and never have to test again? This is also a good time to add a coolant filter, change the upper rad hose to one from a dual alt truck so it goes around the fan belt and not through it.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 8 Old 09-13-2013, 07:11 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
I have had nothing but trouble from NAPA test kits. They're always expired. I ordered these: http://www.amazon.com/gp/aw/d/B000MIUJMO/ref=mp_s_a_1_1?qid=1379084580&sr=8-1&pi=AC_SX110_SY165 and have had great success. Plus it comes with 50 strips (compared NAPAs 5).
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #5 of 8 Old 09-13-2013, 08:49 AM
Question Changing to ELC
What do you have to do to change from the older style antifreeze to the newer ELC stuff. Besides draining and flushing the radiator and heater core.
Thanks
COP-OUT is offline
post #6 of 8 Old 09-13-2013, 09:06 AM
Quoted: 17 Post(s)
Thanks
A good flush should cover it if you have a 99.5+ PSD.
Coolant changing instructions... - Diesel Forum - TheDieselStop.com
post #7 of 8 Old 09-14-2013, 09:46 AM
Powerstroke Junkie
NCHornet's Avatar
Just a good flush, pick your method, as long as you end up with nothing but distilled water and coolant in the system you will be fine.
The test strips weren't the issue, somebody at Napa needed to pull their head out and look at the exp date, it is on the bottle for a reason. I have had that problem before but I never paid for them. What good is 50 going to do you when they expire before you can ever possibly use them all? Now if you can arrange a group buy it might be worth it.....YMMV.................?
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #8 of 8 Old 09-14-2013, 12:56 PM
Quoted: 19 Post(s)
Yup I bought the 50 pack and passed em around
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
