Replacing front crank seal, what else to do while in there? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2013, 12:44 PM Thread Starter
kbragg430's Avatar
Im going to try to knock out the front crank seal thats been leaking on my truck. Its a new truck to me and was wondering if theres anytjing else i could upgrade/modify while im pulling stuff out. Thanks, Kevin.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #2 of 4 Old 09-12-2013, 12:55 PM
rascal's Avatar
You could upgrade your LPOP and dampner if you wanted to. You could also flush your coolant since you will need to remove radiator to get enough room to work in there.
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #3 of 4 Old 09-13-2013, 06:21 AM
timmyboy76's Avatar
Good luck!
Isnt the melling 208 (great lpop replacement) come with a new front seal? I replaced mine, and cant remember. Hwever, when i did replace my lpop, no radiator/IC/ac condensor..etc, were removed for this job. I did sleep at a holiday inn though, the previous night...
I do remember having to find a different/longer dampner bolt for the HB fit it to be correctly installed. Stock one just wont reach.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 4 Old 09-13-2013, 06:25 AM
rascal's Avatar
That's cool. I just like a lot of room to work and I have knocked a pin hole in the radiator before that required me to pull and it get it repaired. To each his own.
Good luck OP!
Rascal
rascal is offline
