Engine Link App for Iphone - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 09-12-2013, 04:15 AM Thread Starter
Hey guys i bought engine link and the elm 327 wifi adapter to try and use it just like the android app Torque. I got the develepor to put in Ford custom pids like torque has and after work today im gona test them out on my 7.3! I will keep you guys posted on this.
psaz likes this.
2001 Ford ECSB F250
5in turbo back exhuast
AEM Intake
Foil Delete
Glowshift Gauges
PHP Pheonix
JMOEL4 is offline
post #2 of 11 Old 09-12-2013, 07:00 AM
Eco Taxi's Avatar
Interesting, due share updates as them come along
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #3 of 11 Old 09-12-2013, 07:12 AM
Quoted: 17 Post(s)
It looks promising, thinking about getting it myself
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #4 of 11 Old 09-12-2013, 07:48 AM
Carolina444's Avatar
I have the app but it dosent read any data.. How do I add the powerstroke pid's?
Early 99 f250 cclb,244k, ccv, Tymar intake, 4" diamond eye, 5" tip, 140v IDM, php hydra, isspro's, riffraff boots & billet wheel, ebpv delete w/ high flow outlet.
P.I.S injectors coming soon
Carolina444 is offline
post #5 of 11 Old 09-13-2013, 05:17 AM
LSDRob's Avatar
Any up dates on this? Been debating on getting the same app and wifi adapter.
01 extended cab long box F-250 4x4 150,000 and still Rollin. Brand new 4r100 and ts 6 position chip with custom tunes, Garrett gtp38r turbo,Diamond eye 5" turbo back, RiffRaff FRx, RiffRaff HPx, 6637. 4" lift on 37x12.50xR17 with black addict xd series wheels. More to come soon!
LSDRob is offline
post #6 of 11 Old 09-13-2013, 10:29 AM
Well I emailed them and they surprisingly emailed me back the same day.. They said there's some custom pid's on iTunes sharing files, I attempted to look for them on iTunes but not really sure what I'm doing.. Anyone one know how to find shared files on iTunes?
post #7 of 11 Old 05-27-2014, 05:05 PM
Has anybody got this app with custom PIDs to work? I have the app and ELM 327 it works fine with the standard PIDs but when I load the Ford Custom PIDs the engine dies.
'02 F250 2wd Auto, Walker BTM, PHP 6-pos chip, Ford AIS, FPRx, Riffraff Billet Wheel, DB Cool Down.
WesinTX is offline
post #8 of 11 Old 10-30-2014, 09:11 AM
Load Ford Pids
Just long press on the screen, it will show a list of gauges and tools, select one and then you can choose to load pid from file, select Ford.
psaz is offline
post #9 of 11 Old 10-30-2014, 06:43 PM
Gpracer's Avatar
Quoted: 5 Post(s)
You may need to disable mode $09
I use the Dashcommand app for iphone with enhanced ford pids.
2000 F-350 Crew Cab Dually long bed, 4R100 w/PTO, Banks Stinger Plus System, Riffraff turbo wheel, bellowed ceramic coated up pipes, turbo blanket, Ford Blue Fuel Pressure Regulator Spring, PHP Hydra, Banks Automind Prog., Trans Boost Pyro Pod Gauges, 6.0 Trans Cooler, Ford AIS Airbox, Firestone Airbags w/pump, Extended Height Cap, 55W HID projectors.
Gpracer is offline
post #10 of 11 Old 10-31-2014, 03:45 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yeah dashcommand is worth buying.
It has ICP but doesn't seem to have IPR, at least with the Android version
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
