My 1st Powerstroke! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-11-2013, 02:33 PM Thread Starter
Talking My 1st Powerstroke!
So I just picked up a 2000 f250 ext. cab long bed 7.3L for my business. After driving around in a 90 F150 for the last 5-6 years this thing runs like a dream.
I bought it from the original owner and it has 105k miles on it, was used for towing a 5th wheel here and there, and was mainly an older lady's truck.
This is my first diesel, got it partly due to all the good things I've read about it on this forum and elsewhere. I've owned gas trucks all my life, and even then never knew too much about them.
I want this puppy to run strong for a looong time, so I need some help!
What should I do to as maintenance about this time? Anything I should know about or look for? If some of you guys that have owned a 7.3L for a long time could help me out I sure would appreciate it!
What would be the first things you would do if you bought this truck just now?
Thanks! I'm excited to get to work fixing this thing up
New Heights Roofing is offline
post #2 of 14 Old 09-11-2013, 02:50 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
This question is asked about once a week. Here's the latest/greatest answer:
Originally Posted by NCHornet View Post
15w-40 is the oil you should use year round where you live. If you lived where it really gets cold in the winter you would want to switch to a lighter weight fluid, at least in Winter.
As for coolant, you truck should have come with the new, at the time, Gold coolant, not green. It looks more brown than gold though. Also just to clear this up, if you are running traditional green coolant, you don't have to use a coolant filter, this isn't what a filter is for. The proper way to monitor SCA levels in the coolant is to test it every 6 months and add the proper additive as it is needed. The pre charged filters are useless, you may be over loading the system with sca additives. It doesn't test the coolant so it knows just how much to release, wouldn't that be cool, lol!!!! Instead it is like one of the blue things that you use to stick in the toilet to keep it clean. It slowly breaks down as the water flows over it. That is where pre-charged filters belong, in the commode.
Now running a coolant filter is a good thing to do. The reason for this is because the cast blocks are constantly leaching sand from the casting process. This sand doesn't play well with water pumps and you can guess who wins. Use a non charged filter to remove the sand from the coolant system and this will prolong the life of your water pump. I couldn't believe how much sand came out of mine and the truck only had 21K on it when I added the filter. This is also a good time to switch the upper rad hose to one that is used on a dual alternator set up, this will route the hose around the fan belt and not through it, another brilliant Ford idea!! If you are changing the coolant it is a good time to switch to a true ELC coolant like the Fleetrite, and you don't have to worry about checking SCA's for 300K and out to 600K if you use the extender at 300K. I myself will never leave any fluid in the truck that long, but it is good that I could.
One of the most neglected fluids is brake fluid. Brake fluid attracts water/moisture. Ever notice when you bleed to brakes the first fluid that comes out is jet black, that is the water in the system. I change mine every 2 years, if I tow heavy I will do it more often. Last time I flushed I used the Super Blue brake fluid and I have been very happy with it. It doesn't attract water, and it has a higher boiling point, this means it can stay in longer, but I will still flush it at the 3 to 4 year mark.
Speaking of brakes, Ford used the cheapest rotors they could on these trucks. Turning them will help until you heat the rotor up again. You can't turn a hard spot out of a rotor. I replaced mine in 2005 with Powerslot/Hawks cyro'd rotors and Hawks LTS pads and couldn't be happier. I also changed the front brake lines to SS which helped firm the pedal up. If you know Fancy Gap mountain on hwy 77, I came down that mountain towing a friends 20K trailer and 1/4 of the way down lost trailer brakes, a true butt puckering moment!!!!! The brake upgrades proved themselves to me, I sure wouldn't of wanted to come down that mountain with that load with a stock brake system.
Replace trans every 30-35K, or 20-25K if you tow a lot. Only use Mercon III fluid, if you have a stock trans, if your trans has been rebuilt in the last few years it is okay to use Mercon V. Please, nobody reply with "Mercon V" is now approved for the 4R100". I have proved it many times on this forum. Your owners manual says NOT TO USE MERCON V in the 4R100. Then all of a sudden in 2007 Ford came out and announced that Mercon V was now approved. But they never said why, what changed. I went as far to contact the refineries that make this fluid and asked if it had been reformulated in any way the way so many claimed. False, no change was ever made. Mercon V won't kill the trans in 20 miles, more like 20-30K, it takes time to destroy the materials in the trans. Ford knew darn well that by the time it caused any issues they would be long out of warranty and they stood a chance of selling the owner a new trans. If you think Ford wouldn't do that you are mistaken. They did the same thing when they switched to the gold coolant in 2005 (IIRC) they claimed it was maintenance Free free for 100K, that was until some of us started to test it. Right out of the jug is failed miserably at meeting min levels of sca. But do you have any idea how much money they saved by using one fluid for all their cars and trucks? It was multiple millions of dollars.
Transfer case, use a good synthetic fluid, which is ATF. Mercon V can be used in the Transfer case with no issues.
Flush power steering fluid with a quality synthetic ATF fluid and it will help in cold weather and turning when truck is just at a idle.
Ball Joints don't last on the 7.3 because of the weight of the motor and Ford didn't use serviceable ball joints. Replace when needed with nothing but Moog Ball Joints with zerk fittings and you won't have to worry about ball joints for a long time.
Calipers should be taken apart and the slide pins lubed properly with the correct grease, otherwise you will end up with a frozen caliper pins and a strong pull to one side.
If it were me I would change all radiator and heater hose lines, as well as a new fan belt as it is a good number to remember ( call it 100K ). I keep a log book of what I did and when so I can tell when something needs to be done.
I highly recommend sending a oil sample to Blackstone Labs. You wouldn't believe how much information you can gain from a scan of your oil. I send in every third oil change. They can alert you of a possible problem long before it becomes a failure.
I didn't get into any serious mods, because you didn't ask about that. But another item I recommend is a full set of gauges, trans, pyro, and boost. Even if you keep her stock, these gauges can be a huge help in diagnosing issues you might have. I always recommend these first so you can get a good baseline feel for how the truck performs, so that way you can actually see how different mods really affect your powertrain or really don't. Lot's of internet hype out there!!!!
Most important thing to tell you is to buy a spare cps (cam position sensor) and carry it with you and the tools to change it on the side of the road. 10mm socket, short extension, ratchet, and a flat blade screwdriver. When the cps goes it is like someone shut the key off and you will be dead in the water. I changed mine out in the middle of a thunderstorm in 10 min with a state trooper standing by telling me the whole time that if I didn't have it moved in 5 min he was going to call a wrecker. I think he was shocked that I actually knew what I was doing, lol!!!! When I bought my truck they were $160, now they are under $30 at the dealer, so get one or two and the tools to change it.
If you have any questions on how to do any of the above just send me a PM and I will help you all I can.
Think too about creating a signature (see below at mine for a reference).
Congrats on your new truck
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 14 Old 09-11-2013, 02:56 PM
05krsd's Avatar
Congrats on your new truck.
2005 F250 King Ranch, CCSB, FX4, 4.5 inch rough country lift, Edge Evolution tuner, studded, nitto terra grapplers 35s, custom exhaust, intake, hids. SOLD.
Looking for my next powerstroke.
05krsd is offline
post #4 of 14 Old 09-11-2013, 03:45 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Now post some pics of your new baby!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 14 Old 09-12-2013, 08:13 AM
timmyboy76's Avatar
congrats on the truck.....sounds like you plan on keeping her for a looooonnnngggg time? Do yourself the favor, and invest into an AE.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 14 Old 09-12-2013, 10:20 AM
Powerstroke Junkie
NCHornet's Avatar
Thanks to the member above for posting my reply from the other thread asking the same question. I said in the other thread that it would be nice if one of the mods would make it a "Sticky" because this does get asked multiple times each week.
To the OP, before you ask what AE is, let me tell you. It is a software program that will allow you to scan for codes and run many of the diagnostic tests that Ford charges big $$$ to run. But if you aren't the type of person to turn your own wrench it might not be worth it to you. To me it would be worth it, just so a "so called" mechanic doesn't rip you off when something does go wrong.
Congrats on a fine truck with a lot of life left in it. The 7.3 is one of the best engines ever placed in a pick up, it will last a long time if you do your part. I know several with over 800K and one that should be over a million miles by now and never had the heads off or engine pulled.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 14 Old 09-12-2013, 12:41 PM
kbragg430's Avatar
I recognize that reply NC! Great info.
2002 F350 CCSB SRW 4X4 ~110k
4" MBRP, DIY Tymar, PHP hydra, Edge Insight CTS, 360* thrust, RR billet wheel, delete pedestal and outlet,
Napa ELC, melling 208 Lpop, 6.0 trans cooler, diy coolant filter, 203* thermostat, RR IC boots w/ plenum inserts, frx, hpx, hutch&harpoon
331 hp / 620 tq
Dynod by dynoproven 4/19/14
kbragg430 is offline
post #8 of 14 Old 09-13-2013, 07:40 AM
Powerstroke Junkie
NCHornet's Avatar
Someone PM a mod and get this thread "STUCK" . Please, lol!!!
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
post #9 of 14 Old 09-13-2013, 10:21 AM Thread Starter
Thanks for all that! I'm compiling a huge to-do list. First things I need to do are basic maintenance, not sure when the different services were done so I'm just going to do everything...oil, trans, coolant, diff, brakes, etc.
It's gonna take me awhile to get through it all =) Will update as I go to see what's important next, I appreciate it!
What's an AE? Not even close to understanding all the abbreviations yet.
post #10 of 14 Old 09-14-2013, 06:31 AM
timmyboy76's Avatar
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
