4 wheel drive not working - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-11-2013, 01:34 PM Thread Starter
Just got my 2002 F-350 back from getting the trans rebuilt and my 4x4 doesn't work, may or may not be related. turn the switch on dash no light. checked a bunch of things hubs and connectors on transfer case everything seems ok. Any ideas?
redsranch is offline
post #2 of 7 Old 09-11-2013, 01:56 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
What're your vents doing? Do they blow normally or are they on defrost in every setting? You might need this: http://www.dieselsite.com/1999-2004f...ofhosekit.aspx
If so, its a common dry rot issue. If your lines look fine, trace them to the pump and troubleshoot there.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 7 Old 09-16-2013, 02:05 PM Thread Starter
Read that or a similar post. Don't think it's a vacuum problem. Light on dash not coming on when turned to 4 high or 4 low. Could the trans shop have screwed something up in trasfer case when removing or reinstalling trans?
post #4 of 7 Old 09-16-2013, 02:21 PM
KCCO
KMC_A55's Avatar
I don't know the differences in 02-03 7.3-6.0, so none of this may be relevant. But I just had the same issue in my 03 6.0...
When you initially crank the truck to start it, do the 4x4 and 4lo lights come on momentarily then turn back off? I just ran into the problem. Turned out to be my GEM (or 4wd module). Mine is located behind the glove box. The windshield was leaking and leaked right onto the module and killed it. If you are bored, here is my thread all about it and things I tested. But like I say, it came down to by a new module. $187 later.
4wd just seems dead, not working. Searched with no luck!
2003 F-350 6.0L. CCLB, 6" lift on 35's, 110k miles: Sinister coolant Filter, Sinister EGR delete, Sinister boots, ARP studs, Powermax Turbo, Diamond Eye 4" turboback exhaust, cat-elc, blue spring update, 6.4 banjo bolts, Edge CTS w/ EGT, SCT w/ Gearhead SRL+ tunes, S&B air intake, Atlas 80 FICM tune, water/meth injection, high idle switch, fog light mod, zoodad mod, 07 front end, 07 dash, 08 taillights, 08 mirrors, 14 tailgate,
upfitters, Lock-Right Locker
KMC_A55 is offline
post #5 of 7 Old 09-18-2013, 09:02 AM
Powerstroke Junkie
NCHornet's Avatar
They probably didn't plug something in, this isn't a boost issue, it is electrical, take it back to the shop. Tell them it worked fine when you brought it in there.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 7 Old 09-24-2013, 05:40 PM Thread Starter
Yes the light turns on when started then goes off. No the vents do not change to defrost when 4x4 turned on. All wires seem to be plugged in and not damaged. Can't find any vacuum leaks.
post #7 of 7 Old 09-25-2013, 05:31 AM
miked.'s Avatar
turn it to 4x4, then tap on the motor on top of transfer case. it could be stuck.
miked. is offline
